Sign in!
Home > Structural Sections > Channels >
UPN - European Standard Channels
Dimensions and Static parameters - tapered flanges - Metric Units
UPN european channel
DesignationDepthWidthThickness WebThickness FlangeSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!UPN 50 x 255025564.923.8616.82.56.71.48
insert!UPN 50 x 385038577.125.5926.49.110.63.75
insert!UPN 60 x 306030666.465.0731.64.510.52.16
insert!UPN 65 x 4265425.57.59.037.0957.514.117.75.07
insert!UPN 80 x 45804568118.6410619.426.56.36
insert!UPN 100 x 501005068.513.510.620629.341.28.49
insert!UPN 120 x 5512055791713.436443.260.711.1
insert!UPN 140 x 601406071020.41660562.786.414.8
insert!UPN 160 x 65160657.510.52418.892585.311618.3
insert!UPN 180 x 70180708112822135011415022.4
insert!UPN 200 x 75200758.511.532.225.3191014819127
insert!UPN 220 x 8022080912.537.429.4269019724533.6
insert!UPN 240 x 85240859.51342.333.2360024830039.6
insert!UPN 260 x 9026090101448.337.9482031737147.7
insert!UPN 280 x 9528095101553.341.8628039944857.2
insert!UPN 300 x 100300100101658.843.2803049553567.8
insert!UPN 350 x 100350100141677.360.61284057073475.0
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
