Sign in!
Home > Structural Sections > Channels >
UPE - Channels with Parallel Flanges
Dimensions and Static parameters - Metric Units
upe channel
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!12012060581215.412.136355.460.613.8
insert!14014065591218.414.559978.785.618.2
insert!160160705.59.51221.717.0911107113.922.6
insert!180180755.510.51225.119.7135314415028.6
insert!200200806111329.022.8190918719134.4
insert!220220856.5121333.926.6268226424442.5
insert!24024090712.51538.530.2359931130050.1
insert!270270957.513.51544.835.2525540138960.7
insert!3003001009.5151556.644.4782353852275.6
insert!33033010511161867.853.21101068266789.7
insert!36036011012171877.961.214830844824105
insert!40040011513.5181891.072.22098010451049123
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 20
