BS 4: 1993 - Dimensions and Static parameters - Metric Units
| Designation | Depth | Width | Thickness Web | Thickness Flange | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | 432 x 102 x 65 | 431.8 | 101.6 | 12.2 | 16.8 | 83.4 | 65.5 | 21373 | 627 | 990 | 80 |
| insert! | 381 x 102 x 55 | 381 | 101.6 | 10.4 | 16.3 | 70.1 | 55.0 | 14869 | 579 | 781 | 75.7 |
| insert! | 305 x 102 x 46 | 304.8 | 101.6 | 10.2 | 14.8 | 58.9 | 46.2 | 8208 | 499 | 539 | 66.5 |
| insert! | 305 x 89 x 42 | 304.8 | 88.9 | 10.2 | 13.7 | 53.3 | 41.8 | 7078 | 326 | 464 | 48.6 |
| insert! | 254 x 89 x 36 | 254 | 88.9 | 9.1 | 13.6 | 45.4 | 35.7 | 4445 | 302 | 350 | 46.7 |
| insert! | 254 x 76 x 28 | 254 | 76.2 | 8.1 | 10.9 | 35.9 | 28.2 | 3355 | 162 | 264 | 28.1 |
| insert! | 229 x 89 x 33 | 228.6 | 88.9 | 8.6 | 13.3 | 41.6 | 32.7 | 3383 | 285 | 296 | 44.8 |
| insert! | 229 x 76 x 26 | 228.6 | 76.2 | 7.6 | 11.2 | 33.2 | 26.1 | 2615 | 159 | 229 | 28.4 |
| insert! | 203 x 89 x 30 | 203.2 | 88.9 | 8.1 | 12.9 | 37.9 | 29.8 | 2492 | 265 | 245 | 42.4 |
| insert! | 203 x 76 x 24 | 203.2 | 76.2 | 7.1 | 11.2 | 30.4 | 23.9 | 1955 | 152 | 192 | 27.7 |
| insert! | 178 x 89 x 27 | 177.8 | 88.9 | 7.6 | 12.3 | 34.1 | 26.8 | 1753 | 241 | 197 | 39.3 |
| insert! | 178 x 76 x 21 | 177.8 | 76.2 | 6.6 | 10.3 | 26.6 | 20.8 | 1338 | 134 | 151 | 24.8 |
| insert! | 152 x 89 x 24 | 152.4 | 88.9 | 7.1 | 11.6 | 30.4 | 23.9 | 1168 | 216 | 153 | 35.8 |
| insert! | 152 x 76 x 18 | 152.4 | 76.2 | 6.4 | 9 | 22.8 | 17.9 | 852 | 114 | 112 | 21 |
| insert! | 127 x 64 x 15 | 127 | 63.5 | 6.4 | 9.2 | 19 | 14.9 | 482 | 67.2 | 76 | 15.2 |
| insert! | 102 x 51 x 10 | 101.6 | 50.8 | 6.1 | 7.6 | 13.3 | 10.4 | 207 | 29.1 | 41 | 8.1 |
| insert! | 76 x 38 x 7 | 76.2 | 38.1 | 5.1 | 6.8 | 8.56 | 6.7 | 74 | 10.7 | 19.5 | 4.1 |
| custom! | |||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 19
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
