Dimensions and Static parameters - Metric Units
| Designation | Depth | Width | Thickness Web | Thickness Flange | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | PFC 100 x 50 x 10 | 100 | 50 | 5 | 8.5 | 10.2 | |||||
| insert! | PFC 125 x 65 x 15 | 125 | 65 | 5.5 | 9.5 | 14.8 | |||||
| insert! | PFC 150 x 75 x 18 | 150 | 75 | 5.5 | 10 | 17.9 | |||||
| insert! | PFC 150 x 90 x 24 | 150 | 90 | 6.5 | 12 | 23.9 | |||||
| insert! | PFC 180 x 75 x 20 | 180 | 75 | 6 | 10.5 | 25.9 | 20.3 | 1370 | 146 | 152 | 28.8 |
| insert! | PFC 180 x 90 x 26 | 180 | 90 | 6.5 | 12.5 | 26.1 | |||||
| insert! | PFC 200 x 75 x 23 | 200 | 75 | 6 | 12.5 | 23.4 | |||||
| insert! | PFC 200 x 90 x 30 | 200 | 90 | 7 | 14 | 29.7 | |||||
| insert! | PFC 230 x 75 x 26 | 230 | 75 | 6.5 | 12.5 | 25.7 | |||||
| insert! | PFC 230 x 90 x 32 | 230 | 90 | 7.5 | 14 | 32.2 | |||||
| insert! | PFC 260 x 75 x 28 | 260 | 75 | 7 | 12 | 27.6 | |||||
| insert! | PFC 260 x 90 x 35 | 260 | 90 | 8 | 14 | 34.8 | |||||
| insert! | PFC 300 x 90 x 41 | 300 | 90 | 9 | 15.5 | 41.4 | |||||
| insert! | PFC 300 x 100 x 46 | 300 | 100 | 9 | 16.5 | 58.0 | 45.5 | 8229 | 568 | 549 | 81.7 |
| insert! | PFC 380 x 100 x 54 | 380 | 100 | 9.5 | 17.5 | 54 | |||||
| insert! | PFC 430 x 100 x 64 | 430 | 100 | 11 | 19 | 64.4 | |||||
| custom! | |||||||||||
Static information for UK PFC - British U-profile with Parallel Flanges wanted.
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 3
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
