Sign in!
Home > Structural Sections > Channels >
ISMC Indian Channels
Dimensions and Static parameters - Metric Units
ismc indian channel
DesignationDepthWidthThickness WebThickness FlangeSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!250 x 80250807.214.13930.6388021130738.5
insert!250 x 8225082914.143.534.2408024432640.9
insert!300 x 90300907.813.646.336.3642031342847.1
insert!400 x 1004001008.815.363.850.11520050876067
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 9
