Home
Structural and Bar Sections
Channels
Dimensions and static parameters MC channels
ASTM Designation: A6/A6M - 12, Standard Specification for General Requirements for Rolled Structural Steel Bars, Plates, Shapes, and Sheet Piling - "MC" Shapes
Designation | Depth | Width | Thickness Web | Thickness Flange | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Sx | Section of Modulus - Sy | |
in | in | in | in | in**2 | lb/ft | in**4 | in**4 | in**3 | in**3 | ||
insert! | MC 18 x 58 | 18.00 | 4.200 | 0.700 | 0.625 | 17.1 | 58 | ||||
insert! | MC 18 x 51.9 | 18.00 | 4.100 | 0.600 | 0.625 | 15.3 | 51.9 | ||||
insert! | MC 18 x 45.8 | 18.00 | 4.000 | 0.500 | 0.625 | 13.5 | 45.8 | ||||
insert! | MC 18 x 42.7 | 18.00 | 3.950 | 0.450 | 0.625 | 12.6 | 42.7 | ||||
insert! | MC 13 x 50 | 13.00 | 4.412 | 0.787 | 0.610 | 14.7 | 50 | ||||
insert! | MC 13 x 40 | 13.00 | 4.185 | 0.560 | 0.610 | 11.8 | 40 | ||||
insert! | MC 13 x 35 | 13.00 | 4.072 | 0.447 | 0.610 | 10.3 | 35 | ||||
insert! | MC 13 x 31.8 | 13.00 | 4.000 | 0.375 | 0.610 | 9.35 | 31.8 | ||||
insert! | MC 12 x 50 | 12.00 | 4.135 | 0.835 | 0.700 | 14.7 | 50 | ||||
insert! | MC 12 x 45 | 12.00 | 4.010 | 0.710 | 0.700 | 13.2 | 45 | ||||
insert! | MC 12 x 40 | 12.00 | 3.890 | 0.590 | 0.700 | 11.8 | 40 | ||||
insert! | MC 12 x 35 | 12.00 | 3.765 | 0.465 | 0.700 | 10.3 | 35 | ||||
insert! | MC 12 x 31 | 12.00 | 3.670 | 0.370 | 0.700 | 9.12 | 31 | ||||
insert! | MC 12 x 14.3 | 12.00 | 2.125 | 0.250 | 0.313 | 4.19 | 14.3 | ||||
insert! | MC 12 x 10.6 | 12.00 | 1.500 | 0.190 | 0.309 | 3.10 | 10.6 | ||||
insert! | MC 10 x 41.1 | 10.00 | 4.321 | 0.796 | 0.575 | 12.1 | 41.1 | ||||
insert! | MC 10 x 33.6 | 10.00 | 4.100 | 0.575 | 0.575 | 9.87 | 33.6 | ||||
insert! | MC 10 x 28.5 | 10.00 | 3.950 | 0.425 | 0.575 | 8.37 | 28.5 | ||||
insert! | MC 10 x 25 | 10.00 | 3.405 | 0.380 | 0.575 | 7.35 | 25 | ||||
insert! | MC 10 x 22 | 10.00 | 3.315 | 0.290 | 0.575 | 6.45 | 22 | ||||
insert! | MC 10 x 8.4 | 10.00 | 1.500 | 0.170 | 0.280 | 2.46 | 8.4 | ||||
insert! | MC 10 x 6.5 | 10.00 | 1.17 | 0.152 | 0.202 | 1.91 | 6.5 | ||||
insert! | MC 9 x 25.4 | 9.00 | 3.500 | 0.450 | 0.550 | 7.47 | 25.4 | ||||
insert! | MC 9 x 23.9 | 9.00 | 3.450 | 0.400 | 0.550 | 7.02 | 23.9 | ||||
insert! | MC 8 x 22.8 | 8.00 | 3.502 | 0.427 | 0.525 | 6.70 | 22.8 | ||||
insert! | MC 8 x 21.4 | 8.00 | 3.450 | 0.375 | 0.525 | 6.28 | 21.4 | ||||
insert! | MC 8 x 20 | 8.00 | 3.025 | 0.400 | 0.500 | 5.88 | 20 | ||||
insert! | MC 8 x 18.7 | 8.00 | 2.978 | 0.353 | 0.500 | 5.50 | 18.7 | ||||
insert! | MC 8 x 8.5 | 8.00 | 1.874 | 0.179 | 0.311 | 2.50 | 8.5 | ||||
insert! | MC 7 x 22.7 | 7.00 | 3.603 | 0.503 | 0.500 | 6.67 | 22.7 | ||||
insert! | MC 7 x 19.1 | 7.00 | 3.452 | 0.352 | 0.500 | 5.61 | 19.1 | ||||
insert! | MC 6 x 18 | 6.00 | 3.504 | 0.379 | 0.475 | 5.29 | 18 | ||||
insert! | MC 6 x 15.3 | 6.00 | 3.500 | 0.340 | 0.385 | 4.50 | 15.3 | ||||
insert! | MC 6 x 16.3 | 6.00 | 3.000 | 0.375 | 0.475 | 4.79 | 16.3 | ||||
insert! | MC 6 x 15.1 | 6.00 | 2.941 | 0.316 | 0.475 | 4.44 | 15.1 | ||||
insert! | MC 6 x 12 | 6.00 | 2.497 | 0.310 | 0.375 | 3.53 | 12 | ||||
insert! | MC4 x 13.8 | 4.00 | 2.5 | 0.5 | 13.8 | ||||||
insert! | MC3 x 7.1 | 3.00 | 1.938 | 0.312 | 7.1 | ||||||
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
