Sign in!
Home > Structural Sections > Channels >
Aluminum Association Standard Channels
Dimensions and Static parameters - Imperial Units
american standard channel
DesignationDepthWidthThickness WebThickness FlangeSectional AreaWeightFillet RadiusMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
ininininin**2lb/ftinin**4in**4in**3in**3
insert!2 x 1210.130.130.4910.5770.100.2880.0450.2880.064
insert!2 x 1 1/421.250.170.260.9111.0710.150.5460.1390.5460.178
insert!3 x 1 1/231.50.130.200.9651.1350.251.410.220.940.22
insert!3 x 1 3/431.750.170.261.3581.5970.251.970.421.310.37
insert!4 x 2420.150.231.4781.7380.253.910.601.950.45
insert!4 x 2 1/442.250.190.291.9822.3310.255.211.022.600.69
insert!5 x 2 1/452.250.150.261.8812.2120.307.880.983.150.64
insert!5 x 2 3/452.750.190.322.6273.0890.3011.142.054.451.14
insert!6 x 2 1/262.50.170.292.4102.8340.3014.351.534.780.90
insert!6 x 3 1/463.250.210.353.4274.0300.3021.043.767.011.76
insert!7 x 2 3/472.750.170.292.7253.2050.3022.092.106.311.10
insert!7 x 3 1/273.50.210.384.0094.7150.3033.795.139.652.23
insert!8 x 3830.190.353.5264.1470.3037.403.259.351.57
insert!8 x 3 3/483.750.250.474.9235.7890.3552.697.1313.172.82
insert!9 x 3 1/493.250.230.354.2374.9830.3554.414.4012.091.89
insert!9 x 4940.290.445.9276.9700.3578.319.6117.403.49
insert!10 x 3 1/2103.50.250.415.2186.1360.3583.226.3316.642.56
insert!10 x 4 1/4104.250.310.507.1098.3600.40116.1513.0223.234.47
insert!12 x 41240.290.477.0368.2740.40159.7911.0326.633.86
insert!12 x 51250.350.6210.05311.8220.45239.6925.7439.957.60
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
