European I Beams - IPN, dimensions and properties
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Flange Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | 80 | 80 | 42 | 3.9 | 5.9 | 3.9 | 2.3 | 7.58 | 5.94 | 77.8 | 6.28 | 19.5 | 3.00 |
| insert! | 100 | 100 | 50 | 4.5 | 6.8 | 4.5 | 2.7 | 10.6 | 8.32 | 170 | 12.1 | 34.2 | 4.88 |
| insert! | 120 | 120 | 58 | 5.1 | 7.7 | 5.1 | 3.1 | 14.2 | 11.2 | 328 | 21.4 | 54.7 | 7.41 |
| insert! | 140 | 140 | 66 | 5.7 | 8.6 | 5.7 | 3.4 | 18.3 | 14.4 | 572 | 35.1 | 81.9 | 10.7 |
| insert! | 160 | 160 | 74 | 6.3 | 9.5 | 6.3 | 3.8 | 22.8 | 17.9 | 934 | 54.7 | 118 | 14.8 |
| insert! | 180 | 180 | 82 | 6.9 | 10.5 | 6.9 | 4.1 | 27.9 | 21.9 | 1450 | 81.3 | 161 | 19.8 |
| insert! | 200 | 200 | 90 | 7.5 | 11.3 | 7.5 | 4.5 | 33.5 | 26.3 | 2140 | 118 | 214 | 26.0 |
| insert! | 220 | 220 | 98 | 8.1 | 12.2 | 8.1 | 4.9 | 39.6 | 31.1 | 3060 | 162 | 278 | 33.1 |
| insert! | 240 | 240 | 106 | 8.7 | 13.1 | 8.7 | 5.2 | 46.1 | 36.2 | 4250 | 222 | 354 | 41.7 |
| insert! | 250 | 250 | 110 | 9 | 13.6 | 9 | 5.4 | 49.7 | 39 | 4960 | 256 | 398 | 46.4 |
| insert! | 260 | 260 | 113 | 9.4 | 14.1 | 9.4 | 5.6 | 53.3 | 41.9 | 5740 | 288 | 442 | 51.0 |
| insert! | 280 | 280 | 119 | 10.1 | 15.2 | 10.1 | 6.1 | 61.1 | 48 | 7590 | 364 | 542 | 61.2 |
| insert! | 300 | 300 | 125 | 10.8 | 16.2 | 10.8 | 6.5 | 69.1 | 54.2 | 9800 | 450 | 653 | 72.2 |
| insert! | 320 | 320 | 131 | 11.5 | 17.3 | 11.5 | 6.9 | 77.8 | 61.1 | 12510 | 556 | 782 | 84.7 |
| insert! | 340 | 340 | 137 | 12.2 | 18.3 | 12.2 | 7.3 | 86.8 | 68.1 | 15700 | 674 | 923 | 98.4 |
| insert! | 360 | 360 | 143 | 13 | 19.5 | 13 | 7.8 | 97.1 | 76.2 | 19610 | 818 | 1090 | 114 |
| insert! | 380 | 380 | 149 | 13.7 | 20.5 | 13.7 | 8.2 | 107 | 84 | 24010 | 975 | 1260 | 131 |
| insert! | 400 | 400 | 155 | 14.4 | 21.6 | 14.4 | 8.6 | 118 | 92.6 | 29210 | 1160 | 1460 | 149 |
| insert! | 425 | 425 | 163 | 15.3 | 23 | 15.3 | 9.2 | 132 | 104 | 36970 | 1440 | 1740 | 176 |
| insert! | 450 | 450 | 170 | 16.2 | 24.3 | 16.2 | 9.7 | 147 | 115 | 45850 | 1730 | 2040 | 203 |
| insert! | 475 | 475 | 178 | 17.1 | 25.6 | 17.1 | 10.3 | 163 | 128 | 56480 | 2090 | 2380 | 235 |
| insert! | 500 | 500 | 185 | 18 | 27 | 18 | 10.8 | 180 | 141 | 68740 | 2480 | 2750 | 268 |
| insert! | 550 | 550 | 200 | 19 | 30 | 19 | 11.9 | 213 | 167 | 99180 | 3490 | 3610 | 349 |
| insert! | 600 | 600 | 215 | 21.6 | 32.4 | 21.6 | 13 | 254 | 199 | 138900 | 4070 | 4630 | 434 |
| custom! | |||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
