HEAA steel beams according DIN 1025 and Euronorm 53-62
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | 100 AA | 91 | 100 | 4.2 | 5.5 | 12 | 15.6 | 12.2 | 236.5 | 92.1 | 52.0 | 18.4 |
| insert! | 120 AA | 109 | 120 | 4.2 | 5.5 | 12 | 18.6 | 14.6 | 413.4 | 159 | 75.9 | 26.5 |
| insert! | 140 AA | 128 | 140 | 4.3 | 6 | 12 | 23.0 | 18.1 | 719.5 | 275 | 112 | 39.3 |
| insert! | 160 AA | 148 | 160 | 4.5 | 7 | 15 | 30.4 | 23.8 | 1283 | 479 | 173 | 59.9 |
| insert! | 180 AA | 167 | 180 | 5 | 7.5 | 15 | 36.3 | 28.7 | 1967 | 730 | 236 | 81.1 |
| insert! | 200 AA | 186 | 200 | 5.5 | 8 | 18 | 44.1 | 34.6 | 2944 | 1068 | 317 | 107 |
| insert! | 220 AA | 205 | 220 | 6 | 8.5 | 18 | 51.5 | 40.4 | 4170 | 1510 | 407 | 137 |
| insert! | 240 AA | 224 | 240 | 6.5 | 9 | 21 | 60.4 | 47.4 | 5835 | 2077 | 521 | 173 |
| insert! | 260 AA | 244 | 260 | 6.5 | 9.5 | 24 | 69.0 | 54.1 | 7981 | 2788 | 654 | 215 |
| custom! | ||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 8
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
