IPE medium flange I-Beams according Euronorm 19-57
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | 80 | 80 | 46 | 3.8 | 5.2 | 5 | 7.64 | 6 | 80.1 | 8.49 | 20 | 3.69 |
| insert! | 100 | 100 | 55 | 4.1 | 5.7 | 7 | 10.3 | 8.1 | 171 | 15.9 | 34.2 | 5.79 |
| insert! | 120 | 120 | 64 | 4.4 | 6.3 | 7 | 13.2 | 10.4 | 318 | 27.7 | 53 | 8.65 |
| insert! | 140 | 140 | 73 | 4.7 | 6.9 | 7 | 16.4 | 12.9 | 541 | 44.9 | 77.3 | 12.3 |
| insert! | 160 | 160 | 82 | 5 | 7.7 | 9 | 20.1 | 15.8 | 869 | 68.3 | 109 | 16.7 |
| insert! | 180 | 180 | 91 | 5.3 | 8 | 9 | 23.9 | 18.8 | 1320 | 101 | 146 | 22.2 |
| insert! | 200 | 200 | 100 | 5.6 | 8.5 | 12 | 28.5 | 22.4 | 1940 | 142 | 194 | 28.5 |
| insert! | 220 | 220 | 110 | 5.9 | 9.2 | 12 | 33.4 | 26.2 | 2770 | 205 | 252 | 37.3 |
| insert! | 240 | 240 | 120 | 6.2 | 9.8 | 15 | 39.1 | 30.7 | 3890 | 284 | 324 | 47.3 |
| insert! | 270 | 270 | 135 | 6.6 | 10.2 | 15 | 45.9 | 36.1 | 5790 | 420 | 429 | 62.2 |
| insert! | 300 | 300 | 150 | 7.1 | 10.7 | 15 | 53.8 | 42.2 | 8360 | 604 | 557 | 80.5 |
| insert! | 330 | 330 | 160 | 7.5 | 11.5 | 18 | 62.5 | 49.1 | 11770 | 788 | 713 | 98.5 |
| insert! | 360 | 360 | 170 | 8 | 12.7 | 18 | 72.7 | 57.1 | 16270 | 1040 | 904 | 123 |
| insert! | 400 | 400 | 180 | 8.6 | 13.5 | 21 | 84.5 | 66.3 | 23130 | 1320 | 1160 | 146 |
| insert! | 450 | 450 | 190 | 9.4 | 14.6 | 21 | 98.8 | 77.6 | 33740 | 1680 | 1500 | 176 |
| insert! | 500 | 500 | 200 | 10.2 | 16 | 21 | 116 | 90.7 | 48200 | 2140 | 1930 | 214 |
| insert! | 550 | 550 | 210 | 11.1 | 17.2 | 24 | 134 | 106 | 67120 | 2670 | 2440 | 254 |
| insert! | 600 | 600 | 220 | 12 | 19 | 24 | 156 | 122 | 92080 | 3390 | 3070 | 308 |
| custom! | ||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 19
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
