Sign in!
Home > Structural Sections > Flange Beams and Columns >
HP - American Wide Flange Bearing Piles
Properties of American wide flange bearing piles - Metric Units
hp american bearing pile
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2lb/ftcm**4cm**4cm**3cm**3
insert!HP 8 x 29200205991054.12938881294389126
insert!HP 8 x 3620420711.311.31068.43649771673488162
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 9
