Home
Structural and Bar Sections
Flange Beams and Columns
ASTM A6 - Dimensions and static parameters of American steel wide flange beams - Imperial Units
ASTM Designation: A6/A6M - 12, Standard Specification for General Requirements for Rolled Structural Steel Bars, Plates, Shapes, and Sheet Piling - "W" Shapes
Designation |
Depth in |
Width in |
Thickness Web in |
Thickness Flange in |
Sectional Area in**2 |
Weight lb/ft |
Moment of Inertia - Ix in**4 |
Moment of Inertia - Iy in**4 |
Section of Modulus - Sx in**3 |
Section of Modulus - Sy in**3 |
| insert! | W 44 x 335 | 44.02 | 15.95 | 1.02 | 1.77 | 98.3 | 335 | ||||
| insert! | W 44 x 290 | 43.62 | 15.83 | 0.87 | 1.58 | 85.8 | 290 | ||||
| insert! | W 44 x 262 | 43.31 | 15.75 | 0.79 | 1.42 | 77.2 | 262 | ||||
| insert! | W 44 x 230 | 42.91 | 15.75 | 0.71 | 1.22 | 67.7 | 230 | ||||
| insert! | W 40 x 593 | 42.99 | 16.69 | 1.79 | 3.23 | 174 | 593 | ||||
| insert! | W 40 x 503 | 42.05 | 16.42 | 1.54 | 2.76 | 148 | 503 | ||||
| insert! | W 40 x 431 | 41.26 | 16.22 | 1.34 | 2.36 | 127 | 431 | ||||
| insert! | W 40 x 372 | 40.63 | 16.06 | 1.16 | 2.05 | 109 | 372 | ||||
| insert! | W 40 x 321 | 40.08 | 15.91 | 1 | 1.77 | 94.1 | 321 | ||||
| insert! | W 40 x 297 | 39.84 | 15.825 | 0.93 | 1.65 | 87.4 | 297 | ||||
| insert! | W 40 x 277 | 39.69 | 15.83 | 0.83 | 1.575 | 81.3 | 277 | ||||
| insert! | W 40 x 249 | 39.38 | 15.75 | 0.75 | 1.42 | 73.3 | 249 | ||||
| insert! | W 40 x 215 | 38.98 | 15.75 | 0.65 | 1.22 | 63.3 | 215 | ||||
| insert! | W 40 x 199 | 38.67 | 15.75 | 0.65 | 1.065 | 58.4 | 199 | ||||
| insert! | W 40 x 174 | 38.2 | 15.75 | 0.65 | 0.83 | 51.1 | 174 | ||||
| insert! | W 40 x 466 | 42.44 | 12.64 | 1.67 | 2.95 | 137 | 466 | ||||
| insert! | W 40 x 392 | 41.57 | 12.36 | 1.42 | 2.52 | 115 | 392 | ||||
| insert! | W 40 x 331 | 40.79 | 12.17 | 1.22 | 2.13 | 97.6 | 331 | ||||
| insert! | W 40 x 278 | 40.16 | 11.97 | 1.02 | 1.81 | 81.8 | 278 | ||||
| insert! | W 40 x 264 | 40 | 11.93 | 0.96 | 1.73 | 77.6 | 264 | ||||
| insert! | W 40 x 235 | 39.69 | 11.89 | 0.83 | 1.575 | 68.9 | 235 | ||||
| insert! | W 40 x 211 | 39.37 | 11.81 | 0.75 | 1.415 | 62 | 211 | ||||
| insert! | W 40 x 183 | 38.98 | 11.81 | 0.65 | 1.22 | 53.7 | 183 | ||||
| insert! | W 40 x 167 | 38.59 | 11.81 | 0.65 | 1.025 | 49.1 | 167 | ||||
| insert! | W 40 x 149 | 38.2 | 11.81 | 0.63 | 0.83 | 43.8 | 149 | ||||
| insert! | W 36 x 848 | 42.45 | 18.13 | 2.52 | 4.53 | 249 | 848 | ||||
| insert! | W 36 x 798 | 41.97 | 17.99 | 2.38 | 4.29 | 234 | 798 | ||||
| insert! | W 36 x 650 | 40.47 | 17.575 | 1.97 | 3.54 | 190 | 650 | ||||
| insert! | W 36 x 527 | 39.21 | 17.22 | 1.61 | 2.91 | 154 | 527 | ||||
| insert! | W 36 x 439 | 38.26 | 16.965 | 1.36 | 2.44 | 128 | 439 | ||||
| insert! | W 36 x 393 | 37.8 | 16.83 | 1.22 | 2.2 | 115 | 393 | ||||
| insert! | W 36 x 359 | 37.4 | 16.73 | 1.12 | 2.01 | 105 | 359 | ||||
| insert! | W 36 x 328 | 37.09 | 16.63 | 1.02 | 1.85 | 96.4 | 328 | ||||
| insert! | W 36 x 300 | 36.74 | 16.655 | 0.945 | 1.68 | 88.3 | 300 | ||||
| insert! | W 36 x 280 | 36.52 | 16.595 | 0.885 | 1.57 | 82.4 | 280 | ||||
| insert! | W 36 x 260 | 36.26 | 16.55 | 0.84 | 1.44 | 76.5 | 260 | ||||
| insert! | W 36 x 245 | 36.08 | 16.51 | 0.8 | 1.35 | 72.1 | 245 | ||||
| insert! | W 36 x 230 | 35.9 | 16.47 | 0.76 | 1.26 | 67.6 | 230 | ||||
| insert! | W 36 x 256 | 37.43 | 12.215 | 0.96 | 1.73 | 75.4 | 256 | ||||
| insert! | W 36 x 232 | 37.12 | 12.12 | 0.87 | 1.57 | 68.1 | 232 | ||||
| insert! | W 36 x 210 | 36.69 | 12.18 | 0.83 | 1.36 | 61.8 | 210 | ||||
| insert! | W 36 x 194 | 36.49 | 12.115 | 0.765 | 1.26 | 57 | 194 | ||||
| insert! | W 36 x 182 | 36.33 | 12.075 | 0.725 | 1.18 | 53.6 | 182 | ||||
| insert! | W 36 x 170 | 36.17 | 12.03 | 0.68 | 1.1 | 50 | 170 | ||||
| insert! | W 36 x 160 | 36.01 | 12 | 0.65 | 1.02 | 47 | 160 | ||||
| insert! | W 36 x 150 | 35.85 | 11.975 | 0.625 | 0.94 | 44.2 | 150 | ||||
| insert! | W 36 x 135 | 35.55 | 11.95 | 0.6 | 0.79 | 39.7 | 135 | ||||
| insert! | W 33 x 354 | 35.55 | 16.1 | 1.16 | 2.09 | 104 | 354 | ||||
| insert! | W 33 x 318 | 35.16 | 15.985 | 1.04 | 1.89 | 93.5 | 318 | ||||
| insert! | W 33 x 291 | 34.84 | 15.905 | 0.96 | 1.73 | 85.6 | 291 | ||||
| insert! | W 33 x 263 | 34.53 | 15.805 | 0.87 | 1.57 | 77.4 | 263 | ||||
| insert! | W 33 x 241 | 34.18 | 15.86 | 0.83 | 1.4 | 70.9 | 241 | ||||
| insert! | W 33 x 221 | 33.93 | 15.805 | 0.775 | 1.275 | 65 | 221 | ||||
| insert! | W 33 x 201 | 33.68 | 15.745 | 0.715 | 1.15 | 59.1 | 201 | ||||
| insert! | W 33 x 169 | 33.82 | 11.5 | 0.67 | 1.22 | 49.5 | 169 | ||||
| insert! | W 33 x 152 | 33.49 | 11.565 | 0.635 | 1.055 | 44.7 | 152 | ||||
| insert! | W 33 x 141 | 33.3 | 11.535 | 0.605 | 0.96 | 41.6 | 141 | ||||
| insert! | W 33 x 130 | 33.09 | 11.51 | 0.58 | 0.855 | 38.3 | 130 | ||||
| insert! | W 33 x 118 | 32.86 | 11.48 | 0.55 | 0.74 | 34.7 | 118 | ||||
| insert! | W 30 x 477 | 34.21 | 15.865 | 1.63 | 2.95 | 140 | 477 | ||||
| insert! | W 30 x 391 | 33.19 | 15.59 | 1.36 | 2.44 | 114 | 391 | ||||
| insert! | W 30 x 326 | 32.4 | 15.37 | 1.14 | 2.05 | 95.7 | 326 | ||||
| insert! | W 30 x 292 | 32.01 | 15.255 | 1.02 | 1.85 | 85.7 | 292 | ||||
| insert! | W 30 x 261 | 31.61 | 15.155 | 0.93 | 1.65 | 76.7 | 261 | ||||
| insert! | W 30 x 235 | 31.3 | 15.055 | 0.83 | 1.5 | 69 | 235 | ||||
| insert! | W 30 x 211 | 30.94 | 15.105 | 0.775 | 1.315 | 62 | 211 | ||||
| insert! | W 30 x 191 | 30.68 | 15.04 | 0.71 | 1.185 | 56.1 | 191 | ||||
| insert! | W 30 x 173 | 30.44 | 14.985 | 0.655 | 1.065 | 50.8 | 173 | ||||
| insert! | W 30 x 148 | 30.67 | 10.48 | 0.65 | 1.18 | 43.5 | 148 | ||||
| insert! | W 30 x 132 | 30.31 | 10.545 | 0.615 | 1 | 38.9 | 132 | ||||
| insert! | W 30 x 124 | 30.17 | 10.515 | 0.585 | 0.93 | 36.5 | 124 | ||||
| insert! | W 30 x 116 | 30.01 | 10.495 | 0.565 | 0.85 | 34.2 | 116 | ||||
| insert! | W 30 x 108 | 29.83 | 10.475 | 0.545 | 0.76 | 31.7 | 108 | ||||
| insert! | W 30 x 99 | 29.65 | 10.45 | 0.52 | 0.67 | 29.1 | 99 | ||||
| insert! | W 30 x 90 | 29.53 | 10.4 | 0.47 | 0.61 | 26.4 | 90 | ||||
| insert! | W 27 x 539 | 32.52 | 15.255 | 1.97 | 3.54 | 158 | 539 | ||||
| insert! | W 27 x 448 | 31.42 | 14.94 | 1.65 | 2.99 | 131 | 448 | ||||
| insert! | W 27 x 368 | 30.39 | 14.665 | 1.38 | 2.48 | 108 | 368 | ||||
| insert! | W 27 x 307 | 29.61 | 14.445 | 1.16 | 2.09 | 90.2 | 307 | ||||
| insert! | W 27 x 258 | 28.98 | 14.27 | 0.98 | 1.77 | 75.7 | 258 | ||||
| insert! | W 27 x 235 | 28.66 | 14.19 | 0.91 | 1.61 | 69.1 | 235 | ||||
| insert! | W 27 x 217 | 28.43 | 14.115 | 0.83 | 1.5 | 63.8 | 217 | ||||
| insert! | W 27 x 194 | 28.11 | 14.035 | 0.75 | 1.34 | 57 | 194 | ||||
| insert! | W 27 x 178 | 27.81 | 14.085 | 0.725 | 1.190 | 52.3 | 178 | 6990 | 555 | 502 | 78.8 |
| insert! | W 27 x 161 | 27.59 | 14.020 | 0.660 | 1.080 | 47.4 | 161 | 6280 | 497 | 455 | 70.9 |
| insert! | W 27 x 146 | 27.38 | 13.965 | 0.605 | 0.975 | 42.9 | 146 | 5630 | 443 | 411 | 63.5 |
| insert! | W 27 x 114 | 27.29 | 10.070 | 0.570 | 0.930 | 33.5 | 114 | 4090 | 159 | 299 | 31.5 |
| insert! | W 27 x 102 | 27.09 | 10.015 | 0.515 | 0.830 | 30.0 | 102 | 3620 | 139 | 267 | 27.8 |
| insert! | W 27 x 94 | 26.92 | 9.990 | 0.490 | 0.745 | 27.7 | 94 | 3270 | 124 | 243 | 24.8 |
| insert! | W 27 x 84 | 26.71 | 9.960 | 0.460 | 0.640 | 24.8 | 84 | 2850 | 106 | 213 | 21.2 |
| insert! | W 24 x 162 | 25.00 | 12.955 | 0.705 | 1.220 | 47.7 | 162 | 5170 | 443 | 414 | 68.4 |
| insert! | W 24 x 146 | 24.74 | 12.900 | 0.650 | 1.090 | 43.0 | 146 | 4580 | 391 | 371 | 60.5 |
| insert! | W 24 x 131 | 24.48 | 12.855 | 0.605 | 0.960 | 38.5 | 131 | 4020 | 340 | 329 | 53.0 |
| insert! | W 24 x 117 | 24.26 | 12.800 | 0.550 | 0.850 | 34.4 | 117 | 3540 | 297 | 291 | 46.5 |
| insert! | W 24 x 104 | 24.06 | 12.750 | 0.500 | 0.750 | 30.6 | 104 | 3100 | 259 | 258 | 40.7 |
| insert! | W 24 x 94 | 24.31 | 9.065 | 0.515 | 0.875 | 27.7 | 94 | 2700 | 109 | 222 | 24.0 |
| insert! | W 24 x 84 | 24.10 | 9.020 | 0.470 | 0.770 | 24.7 | 84 | 2370 | 94.4 | 196 | 20.9 |
| insert! | W 24 x 76 | 23.92 | 8.990 | 0.440 | 0.680 | 22.4 | 76 | 2100 | 82.5 | 176 | 18.4 |
| insert! | W 24 x 68 | 23.73 | 8.965 | 0.415 | 0.585 | 20.1 | 68 | 1830 | 70.4 | 154 | 15.7 |
| insert! | W 24 x 62 | 23.74 | 7.040 | 0.430 | 0.590 | 18.2 | 62 | 1550 | 34.5 | 131 | 9.8 |
| insert! | W 24 x 55 | 23.57 | 7.005 | 0.395 | 0.505 | 16.2 | 55 | 1350 | 29.1 | 114 | 8.3 |
| insert! | W 21 x 147 | 22.06 | 12.510 | 0.720 | 1.150 | 43.2 | 147 | 3630 | 376 | 329 | 60.1 |
| insert! | W 21 x 132 | 21.83 | 14.440 | 0.650 | 1.035 | 38.8 | 132 | 3220 | 333 | 295 | 53.5 |
| insert! | W 21 x 122 | 21.68 | 12.390 | 0.600 | 0.960 | 35.9 | 122 | 2960 | 305 | 273 | 49.2 |
| insert! | W 21 x 111 | 21.51 | 12.340 | 0.550 | 0.875 | 32.7 | 111 | 2670 | 274 | 249 | 44.5 |
| insert! | W 21 x 101 | 21.36 | 12.290 | 0.500 | 0.800 | 29.8 | 101 | 2420 | 248 | 227 | 40.3 |
| insert! | W 21 x 93 | 21.62 | 8.420 | 0.580 | 0.930 | 27.3 | 93 | 2070 | 92.9 | 192 | 22.1 |
| insert! | W 21 x 83 | 21.43 | 8.355 | 0.515 | 0.835 | 24.3 | 83 | 1830 | 81.4 | 171 | 19.5 |
| insert! | W 21 x 73 | 21.24 | 8.295 | 0.455 | 0.740 | 21.5 | 73 | 1600 | 70.6 | 151 | 17.0 |
| insert! | W 21 x 68 | 21.13 | 8.270 | 0.430 | 0.685 | 20.0 | 68 | 1480 | 64.7 | 140 | 15.7 |
| insert! | W 21 x 62 | 20.99 | 8.240 | 0.400 | 0.615 | 18.3 | 62 | 1330 | 57.5 | 127 | 13.8 |
| insert! | W 21 x 57 | 21.06 | 6.555 | 0.405 | 0.650 | 16.7 | 57 | 1170 | 30.6 | 111 | 9.35 |
| insert! | W 21 x 50 | 20.83 | 6.530 | 0.380 | 0.535 | 14.7 | 50 | 984 | 24.4 | 94.5 | 7.64 |
| insert! | W 21 x 44 | 20.66 | 6.500 | 0.350 | 0.450 | 13.0 | 44 | 843 | 20.7 | 81.6 | 6.36 |
| insert! | W 18 x 119 | 18.97 | 11.265 | 0.655 | 1.060 | 35.1 | 119 | 2190 | 253 | 231 | 44.9 |
| insert! | W 18 x 106 | 18.73 | 11.200 | 0.590 | 0.940 | 31.1 | 106 | 1910 | 220 | 204 | 39.4 |
| insert! | W 18 x 97 | 18.59 | 11.145 | 0.535 | 0.870 | 28.5 | 97 | 1750 | 201 | 188 | 36.1 |
| insert! | W 18 x 86 | 18.39 | 11.090 | 0.480 | 0.770 | 25.3 | 86 | 1530 | 175 | 166 | 31.6 |
| insert! | W 18 x 76 | 18.21 | 11.035 | 0.425 | 0.680 | 22.3 | 76 | 1330 | 152 | 146 | 27.6 |
| insert! | W 18 x 71 | 18.47 | 7.635 | 0.495 | 0.810 | 20.8 | 71 | 1170 | 60.3 | 127 | 15.8 |
| insert! | W 18 x 65 | 18.35 | 7.590 | 0.450 | 0.750 | 19.1 | 65 | 1070 | 54.8 | 117 | 14.4 |
| insert! | W 18 x 60 | 18.24 | 7.555 | 0.415 | 0.695 | 17.6 | 60 | 984 | 50.1 | 108 | 13.3 |
| insert! | W 18 x 55 | 18.11 | 7.530 | 0.390 | 0.630 | 16.2 | 55 | 890 | 44.9 | 98.3 | 11.9 |
| insert! | W 18 x 50 | 17.99 | 7.495 | 0.355 | 0.570 | 14.7 | 50 | 800 | 40.1 | 88.9 | 10.7 |
| insert! | W 18 x 46 | 18.09 | 6.060 | 0.360 | 0.605 | 13.5 | 46 | 712 | 22.5 | 78.8 | 7.43 |
| insert! | W 18 x 40 | 17.90 | 6.015 | 0.315 | 0.525 | 11.8 | 40 | 612 | 19.1 | 68.4 | 6.35 |
| insert! | W 18 x 35 | 17.70 | 6.000 | 0.300 | 0.425 | 10.3 | 35 | 510 | 15.3 | 57.6 | 5.12 |
| insert! | W 16 x 100 | 16.97 | 10.425 | 0.585 | 0.985 | 29.4 | 100 | 1490 | 186 | 175 | 35.7 |
| insert! | W 16 x 89 | 16.75 | 10.365 | 0.525 | 0.875 | 26.2 | 89 | 1300 | 163 | 155 | 31.4 |
| insert! | W 16 x 77 | 16.52 | 10.295 | 0.455 | 0.760 | 22.6 | 77 | 1110 | 138 | 134 | 26.9 |
| insert! | W 16 x 67 | 16.33 | 10.235 | 0.395 | 0.665 | 19.7 | 67 | 954 | 119 | 117 | 23.2 |
| insert! | W 16 x 57 | 16.43 | 7.120 | 0.430 | 0.715 | 16.8 | 57 | 758 | 43.1 | 92.2 | 12.1 |
| insert! | W 16 x 50 | 16.26 | 7.070 | 0.380 | 0.630 | 14.7 | 50 | 659 | 37.2 | 81.0 | 10.5 |
| insert! | W 16 x 45 | 16.13 | 7.035 | 0.345 | 0.565 | 13.3 | 45 | 586 | 32.8 | 72.7 | 9.34 |
| insert! | W 16 x 40 | 16.01 | 6.995 | 0.305 | 0.505 | 11.8 | 40 | 518 | 28.9 | 64.7 | 8.25 |
| insert! | W 16 x 36 | 15.86 | 6.985 | 0.295 | 0.430 | 10.6 | 36 | 448 | 24.5 | 56.5 | 7.00 |
| insert! | W 16 x 31 | 15.88 | 5.525 | 0.275 | 0.440 | 9.12 | 31 | 375 | 12.4 | 47.2 | 4.49 |
| insert! | W 16 x 26 | 15.69 | 5.500 | 0.250 | 0.345 | 7.68 | 26 | 301 | 9.59 | 38.4 | 3.49 |
| insert! | W 14 x 730 | 22.42 | 17.890 | 3.070 | 4.910 | 215 | 730 | 14300 | 4720 | 1280 | 527 |
| insert! | W 14 x 665 | 21.64 | 17.650 | 2.830 | 4.520 | 196 | 665 | 12400 | 4170 | 1150 | 472 |
| insert! | W 14 x 605 | 20.92 | 17.415 | 2.595 | 4.160 | 178 | 605 | 10800 | 3680 | 1040 | 423 |
| insert! | W 14 x 550 | 20.24 | 17.200 | 2.380 | 3.820 | 162 | 550 | 9430 | 3250 | 931 | 378 |
| insert! | W 14 x 500 | 19.60 | 17.010 | 2.190 | 3.500 | 147 | 500 | 8210 | 2880 | 838 | 339 |
| insert! | W 14 x 455 | 19.02 | 16.835 | 2.015 | 3.210 | 134 | 455 | 7190 | 2560 | 756 | 304 |
| insert! | W 14 x 426 | 18.67 | 16.695 | 1.875 | 3.035 | 125 | 426 | 6600 | 2360 | 707 | 283 |
| insert! | W 14 x 398 | 18.29 | 16.590 | 1.770 | 2.845 | 117 | 398 | 6000 | 2170 | 656 | 262 |
| insert! | W 14 x 370 | 17.92 | 16.475 | 1.655 | 2.660 | 109 | 370 | 5440 | 1990 | 607 | 241 |
| insert! | W 14 x 342 | 17.57 | 16.360 | 1.540 | 2.470 | 101 | 342 | 4900 | 1810 | 559 | 221 |
| insert! | W 14 x 311 | 17.12 | 16.230 | 1.410 | 2.260 | 91.4 | 311 | 4330 | 1610 | 506 | 199 |
| insert! | W 14 x 283 | 16.74 | 16.110 | 1.290 | 2.070 | 83.3 | 283 | 3840 | 1440 | 459 | 179 |
| insert! | W 14 x 257 | 16.38 | 15.995 | 1.175 | 1.890 | 75.6 | 257 | 3400 | 1290 | 415 | 161 |
| insert! | W 14 x 233 | 16.04 | 15.890 | 1.070 | 1.720 | 68.5 | 233 | 3010 | 1150 | 375 | 145 |
| insert! | W 14 x 211 | 15.72 | 15.800 | 0.980 | 1.560 | 62.0 | 211 | 2660 | 1030 | 338 | 130 |
| insert! | W 14 x 193 | 15.48 | 15.710 | 0.890 | 1.440 | 56.8 | 193 | 2400 | 931 | 310 | 119 |
| insert! | W 14 x 176 | 15.22 | 15.650 | 0.830 | 1.310 | 51.8 | 176 | 2140 | 838 | 281 | 107 |
| insert! | W 14 x 159 | 14.98 | 15.565 | 0.745 | 1.190 | 46.7 | 159 | 1900 | 748 | 254 | 96.2 |
| insert! | W 14 x 145 | 14.78 | 15.500 | 0.680 | 1.090 | 42.7 | 145 | 1710 | 677 | 232 | 87.3 |
| insert! | W 14 x 132 | 14.66 | 14.725 | 0.645 | 1.030 | 38.8 | 132 | 1530 | 548 | 209 | 74.5 |
| insert! | W 14 x 120 | 14.48 | 14.670 | 0.590 | 0.940 | 35.3 | 120 | 1380 | 495 | 190 | 67.5 |
| insert! | W 14 x 109 | 14.32 | 14.605 | 0.525 | 0.860 | 32.0 | 109 | 1240 | 447 | 173 | 61.2 |
| insert! | W 14 x 99 | 14.16 | 14.565 | 0.485 | 0.780 | 29.1 | 99 | 1110 | 402 | 157 | 55.2 |
| insert! | W 14 x 90 | 14.02 | 14.520 | 0.440 | 0.710 | 26.5 | 90 | 999 | 362 | 143 | 49.9 |
| insert! | W 14 x 82 | 14.31 | 10.130 | 0.510 | 0.855 | 24.1 | 82 | 882 | 148 | 123 | 29.3 |
| insert! | W 14 x 74 | 14.17 | 10.070 | 0.450 | 0.785 | 21.8 | 74 | 796 | 134 | 112 | 26.6 |
| insert! | W 14 x 68 | 14.04 | 10.035 | 0.415 | 0.720 | 20.0 | 68 | 723 | 121 | 103 | 24.2 |
| insert! | W 14 x 61 | 13.89 | 9.995 | 0.375 | 0.645 | 17.9 | 61 | 640 | 107 | 92.2 | 21.5 |
| insert! | W 14 x 53 | 13.92 | 8.060 | 0.370 | 0.660 | 15.6 | 53 | 541 | 57.7 | 77.8 | 14.3 |
| insert! | W 14 x 48 | 13.79 | 8.030 | 0.340 | 0.595 | 14.1 | 48 | 485 | 51.4 | 70.3 | 12.8 |
| insert! | W 14 x 43 | 13.66 | 7.995 | 0.305 | 0.530 | 12.6 | 43 | 428 | 45.2 | 62.7 | 11.3 |
| insert! | W 14 x 38 | 14.10 | 6.770 | 0.310 | 0.515 | 11.2 | 38 | 385 | 26.7 | 54.6 | 7.88 |
| insert! | W 14 x 34 | 13.98 | 6.745 | 0.285 | 0.455 | 10.0 | 34 | 340 | 26.3 | 48.6 | 6.91 |
| insert! | W 14 x 30 | 13.84 | 6.730 | 0.270 | 0.385 | 8.85 | 30 | 291 | 19.6 | 42.0 | 5.82 |
| insert! | W 14 x 26 | 13.91 | 5.025 | 0.255 | 0.420 | 7.69 | 26 | 245 | 8.91 | 35.3 | 3.54 |
| insert! | W 14 x 22 | 13.74 | 5.000 | 0.230 | 0.335 | 6.49 | 22 | 199 | 7.00 | 29.0 | 2.80 |
| insert! | W 12 x 336 | 16.82 | 13.385 | 1.775 | 2.955 | 98.8 | 336 | 4060 | 1190 | 483 | 177 |
| insert! | W 12 x 305 | 16.32 | 13.235 | 1.625 | 2.705 | 89.6 | 305 | 3550 | 1050 | 435 | 159 |
| insert! | W 12 x 279 | 15.85 | 13.140 | 1.530 | 2.470 | 81.9 | 279 | 3110 | 937 | 393 | 143 |
| insert! | W 12 x 252 | 15.41 | 13.005 | 1.395 | 2.250 | 74.1 | 252 | 2720 | 828 | 353 | 127 |
| insert! | W 12 x 230 | 15.05 | 12.895 | 1.285 | 2.070 | 67.7 | 230 | 2420 | 742 | 321 | 115 |
| insert! | W 12 x 210 | 14.71 | 12.790 | 1.180 | 1.900 | 61.8 | 210 | 2140 | 664 | 292 | 104 |
| insert! | W 12 x 190 | 14.38 | 12.670 | 1.060 | 1.735 | 55.8 | 190 | 1890 | 589 | 263 | 93.0 |
| insert! | W 12 x 170 | 14.03 | 12.570 | 0.960 | 1.560 | 50.0 | 170 | 1650 | 517 | 235 | 82.3 |
| insert! | W 12 x 152 | 13.71 | 12.480 | 0.870 | 1.400 | 44.7 | 152 | 1430 | 454 | 209 | 72.8 |
| insert! | W 12 x 136 | 13.41 | 12.400 | 0.790 | 1.250 | 39.9 | 136 | 1240 | 398 | 186 | 64.2 |
| insert! | W 12 x 120 | 13.12 | 12.320 | 0.710 | 1.105 | 35.3 | 120 | 1070 | 345 | 163 | 56.0 |
| insert! | W 12 x 106 | 12.89 | 12.220 | 0.610 | 0.990 | 31.2 | 106 | 933 | 301 | 145 | 49.3 |
| insert! | W 12 x 96 | 12.71 | 12.160 | 0.550 | 0.900 | 28.2 | 96 | 833 | 270 | 131 | 44.4 |
| insert! | W 12 x 87 | 12.53 | 12.125 | 0.515 | 0.810 | 25.6 | 87 | 740 | 241 | 118 | 39.7 |
| insert! | W 12 x 79 | 12.38 | 12.080 | 0.470 | 0.735 | 23.2 | 79 | 662 | 216 | 107 | 35.8 |
| insert! | W 12 x 72 | 12.25 | 12.040 | 0.430 | 0.670 | 21.1 | 72 | 597 | 195 | 97.4 | 32.4 |
| insert! | W 12 x 65 | 12.12 | 12.000 | 0.390 | 0.605 | 19.1 | 65 | 533 | 174 | 87.9 | 29.1 |
| insert! | W 12 x 58 | 12.19 | 10.010 | 0.360 | 0.640 | 17.0 | 58 | 475 | 107 | 78.0 | 21.4 |
| insert! | W 12 x 53 | 12.06 | 9.995 | 0.345 | 0.575 | 15.6 | 53 | 425 | 95.8 | 70.6 | 19.2 |
| insert! | W 12 x 50 | 12.19 | 8.080 | 0.370 | 0.640 | 14.7 | 50 | 394 | 56.3 | 64.7 | 13.9 |
| insert! | W 12 x 45 | 12.06 | 8.045 | 0.335 | 0.575 | 13.2 | 45 | 350 | 50.0 | 58.1 | 12.4 |
| insert! | W 12 x 40 | 11.94 | 8.005 | 0.295 | 0.515 | 11.8 | 40 | 310 | 44.1 | 51.9 | 11.0 |
| insert! | W 12 x 35 | 12.50 | 6.560 | 0.300 | 0.520 | 10.3 | 35 | 285 | 24.5 | 45.6 | 7.47 |
| insert! | W 12 x 30 | 12.34 | 6.520 | 0.260 | 0.440 | 8.79 | 30 | 238 | 20.3 | 38.6 | 6.24 |
| insert! | W 12 x 26 | 12.22 | 6.490 | 0.230 | 0.380 | 7.65 | 26 | 204 | 17.3 | 33.4 | 5.34 |
| insert! | W 12 x 22 | 12.31 | 4.030 | 0.260 | 0.425 | 6.48 | 22 | 156 | 4.66 | 25.4 | 2.31 |
| insert! | W 12 x 19 | 12.16 | 4.005 | 0.235 | 0.350 | 5.57 | 19 | 130 | 3.76 | 21.3 | 1.88 |
| insert! | W 12 x 16 | 11.99 | 3.990 | 0.220 | 0.265 | 4.71 | 16 | 103 | 2.82 | 17.1 | 1.41 |
| insert! | W 12 x 14 | 11.91 | 3.970 | 0.200 | 0.225 | 4.16 | 14 | 88.6 | 2.36 | 14.9 | 1.19 |
| insert! | W 10 x 112 | 11.36 | 10.415 | 0.755 | 1.250 | 32.9 | 112 | 716 | 236 | 126 | 45.3 |
| insert! | W 10 x 100 | 11.10 | 10.340 | 0.680 | 1.120 | 29.4 | 100 | 623 | 207 | 112 | 40.0 |
| insert! | W 10 x 88 | 10.84 | 10.265 | 0.605 | 0.990 | 25.9 | 88 | 534 | 179 | 98.5 | 34.8 |
| insert! | W 10 x 77 | 10.60 | 10.190 | 0.530 | 0.870 | 22.9 | 77 | 455 | 154 | 85.9 | 30.1 |
| insert! | W 10 x 68 | 10.40 | 10.130 | 0.470 | 0.770 | 20.0 | 68 | 394 | 134 | 75.7 | 26.4 |
| insert! | W 10 x 60 | 10.22 | 10.080 | 0.420 | 0.680 | 17.6 | 60 | 341 | 116 | 66.7 | 23.0 |
| insert! | W 10 x 54 | 10.09 | 10.030 | 0.370 | 0.615 | 15.8 | 54 | 303 | 103 | 60.0 | 20.6 |
| insert! | W 10 x 49 | 9.98 | 10.000 | 0.340 | 0.560 | 14.4 | 49 | 272 | 93.4 | 54.6 | 18.7 |
| insert! | W 10 x 45 | 10.10 | 8.020 | 0.350 | 0.620 | 13.3 | 45 | 248 | 53.4 | 49.1 | 13.3 |
| insert! | W 10 x 39 | 9.92 | 7.985 | 0.315 | 0.530 | 11.5 | 39 | 209 | 45.0 | 42.1 | 11.3 |
| insert! | W 10 x 33 | 9.73 | 7.960 | 0.290 | 0.435 | 9.71 | 33 | 170 | 36.6 | 35.0 | 9.20 |
| insert! | W 10 x 30 | 10.47 | 5.810 | 0.300 | 0.510 | 8.84 | 30 | 170 | 16.7 | 32.4 | 5.75 |
| insert! | W 10 x 26 | 10.33 | 5.770 | 0.260 | 0.440 | 7.61 | 26 | 144 | 14.1 | 27.9 | 4.89 |
| insert! | W 10 x 22 | 10.17 | 5.750 | 0.240 | 0.360 | 6.49 | 22 | 118 | 11.4 | 23.2 | 3.97 |
| insert! | W 10 x 19 | 10.24 | 4.020 | 0.250 | 0.395 | 5.62 | 19 | 96.3 | 4.29 | 18.8 | 2.14 |
| insert! | W 10 x 17 | 10.11 | 4.010 | 0.240 | 0.330 | 4.99 | 17 | 81.9 | 3.56 | 16.2 | 1.78 |
| insert! | W 10 x 15 | 9.99 | 4.000 | 0.230 | 0.270 | 4.41 | 15 | 68.9 | 2.89 | 13.8 | 1.45 |
| insert! | W 10 x 12 | 9.87 | 3.960 | 0.190 | 0.210 | 3.54 | 12 | 53.8 | 2.18 | 10.9 | 1.10 |
| insert! | W 8 x 67 | 9.00 | 8.280 | 0.570 | 0.935 | 19.7 | 67 | 272 | 88.6 | 60.4 | 21.4 |
| insert! | W 8 x 58 | 8.75 | 8.220 | 0.510 | 0.810 | 17.1 | 58 | 228 | 75.1 | 52.0 | 18.3 |
| insert! | W 8 x 48 | 8.50 | 8.110 | 0.400 | 0.685 | 14.1 | 48 | 184 | 60.9 | 43.3 | 15.0 |
| insert! | W 8 x 40 | 8.25 | 8.070 | 0.360 | 0.560 | 11.7 | 40 | 146 | 49.1 | 35.5 | 12.2 |
| insert! | W 8 x 35 | 8.12 | 8.020 | 0.310 | 0.495 | 10.3 | 35 | 127 | 42.6 | 31.2 | 10.6 |
| insert! | W 8 x 31 | 8.00 | 7.995 | 0.285 | 0.435 | 9.13 | 31 | 110 | 37.1 | 27.5 | 9.27 |
| insert! | W 8 x 28 | 8.06 | 6.535 | 0.285 | 0.465 | 8.25 | 28 | 98.0 | 21.7 | 24.3 | 6.63 |
| insert! | W 8 x 24 | 7.93 | 6.495 | 0.245 | 0.400 | 7.08 | 24 | 82.8 | 18.3 | 20.9 | 5.63 |
| insert! | W 8 x 21 | 8.28 | 5.270 | 0.250 | 0.400 | 6.16 | 21 | 75.3 | 9.77 | 18.2 | 3.71 |
| insert! | W 8 x 18 | 8.14 | 5.250 | 0.230 | 0.330 | 5.26 | 18 | 61.9 | 7.97 | 15.2 | 3.04 |
| insert! | W 8 x 15 | 8.11 | 4.015 | 0.245 | 0.315 | 4.44 | 15 | 48.0 | 3.41 | 11.8 | 1.70 |
| insert! | W 8 x 13 | 7.99 | 4.000 | 0.230 | 0.255 | 3.84 | 13 | 39.6 | 2.73 | 9.91 | 1.37 |
| insert! | W 8 x 10 | 7.89 | 3.940 | 0.170 | 0.205 | 2.96 | 10 | 30.8 | 2.09 | 7.81 | 1.06 |
| insert! | W 6 x 25 | 6.38 | 6.080 | 0.320 | 0.455 | 7.34 | 25 | 53.4 | 17.10 | 16.7 | 5.61 |
| insert! | W 6 x 20 | 6.20 | 6.020 | 0.260 | 0.365 | 5.87 | 20 | 41.4 | 13.30 | 13.4 | 4.41 |
| insert! | W 6 x 16 | 6.28 | 4.030 | 0.260 | 0.405 | 4.74 | 16 | 32.1 | 4.43 | 10.2 | 2.20 |
| insert! | W 6 x 15 | 5.99 | 5.990 | 0.230 | 0.260 | 4.43 | 15 | 29.1 | 9.32 | 9.72 | 3.11 |
| insert! | W 6 x 12 | 6.03 | 4.000 | 0.230 | 0.280 | 3.55 | 12 | 22.1 | 2.99 | 7.31 | 1.50 |
| insert! | W 6 x 9 | 5.90 | 3.940 | 0.170 | 0.215 | 2.68 | 9 | 16.4 | 2.19 | 5.56 | 1.11 |
| insert! | W 5 x 19 | 5.15 | 5.030 | 0.270 | 0.430 | 5.54 | 19 | 26.2 | 9.13 | 10.2 | 3.63 |
| insert! | W 5 x 16 | 5.01 | 5.000 | 0.240 | 0.360 | 4.68 | 16 | 21.3 | 7.51 | 8.51 | 3.00 |
| insert! | W 4 x 13 | 4.16 | 4.060 | 0.280 | 0.345 | 3.83 | 13 | 11.3 | 3.86 | 5.46 | 1.90 |
| custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
