Sign in!
Home > Structural Sections > Flange Beams and Columns >
H - Japanese Sections
Japanese H sections according JIS G 3192:2005
h japanese section
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!H 100 x 10010010068821.616.937813475.626.7
insert!H 125 x 1251251256.59830.023.684029313446.9
insert!H 150 x 751507557817.914.066649.588.913.2
insert!H 150 x 150150150710839.731.1162356321675.1
insert!H 175 x 1751751757.5111351.440.42895938331112
insert!H 198 x 99198994.57822.717.8154311315622.9
insert!H 200 x 1002001005.58826.720.9180613418126.7
insert!H 200 x 2002002008121363.549.947161602472160
insert!H 200 x 20420020412121371.556.249821702498167
insert!H 298 x 1492981495.581340.832.0631844242459.3
insert!H 300 x 1503001506.591346.836.7720950748167.7
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
