Home
Structural and Bar Sections
Flange Beams and Columns
ASTM A6 - Dimensions and static properties of American Standard M Section Beams - Imperial Units
Designation | Depth | Width | Thickness Web | Thickness Flange | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
in | in | in | in | in**2 | lb/ft | in**4 | in**4 | in**3 | in**3 | ||
insert! | M12.5 x 12.4 | 12.534 | 3.750 | 0.155 | 0.228 | 3.66 | 12.4 | ||||
insert! | M12.5 x 11.6 | 12.500 | 3.500 | 0.155 | 0.211 | 3.43 | 11.6 | ||||
insert! | M12 x 11.8 | 12.0 | 3.065 | 0.177 | 0.225 | 3.47 | 11.8 | ||||
insert! | M12 x 10.8 | 11.97 | 3.065 | 0.160 | 0.210 | 3.18 | 10.8 | ||||
insert! | M12 x 11.0 | 11.97 | 3.250 | 0.149 | 0.180 | 2.94 | 11.0 | ||||
insert! | M10 x 9.0 | 10.0 | 2.690 | 0.157 | 0.206 | 2.65 | 9.0 | ||||
insert! | M10 x 8.0 | 9.95 | 2.690 | 0.141 | 0.182 | 2.35 | 8.0 | ||||
insert! | M10 x 7.5 | 9.99 | 2.688 | 0.130 | 0.173 | 2.21 | 7.5 | ||||
insert! | M8 x 6.5 | 8.0 | 2.281 | 0.134 | 0.189 | 1.92 | 6.5 | ||||
insert! | M8 x 6.2 | 8.0 | 2.281 | 0.129 | 0.177 | 1.81 | 6.2 | ||||
insert! | M6 x 4.4 | 6.0 | 1.844 | 0.114 | 0.171 | 1.29 | 4.4 | ||||
insert! | M6 x 3.7 | 5.92 | 2.000 | 0.098 | 0.129 | 1.09 | 3.7 | ||||
insert! | M5 x 18.9 | 5.0 | 5.003 | 0.316 | 0.416 | 5.55 | 18.9 | ||||
insert! | M4 x 6.0 | 3.8 | 3.8 | 0.130 | 0.160 | 1.78 | 6.0 | ||||
insert! | M4 x 4.08 | 4.0 | 2.250 | 0.115 | 0.170 | 1.20 | 4.08 | ||||
insert! | M4 x 3.45 | 4.0 | 2.250 | 0.092 | 0.130 | 1.02 | 3.45 | ||||
insert! | M4 x 3.2 | 4.0 | 2.250 | 0.092 | 0.130 | 0.94 | 3.2 | ||||
insert! | M3 x 2.9 | 3.0 | 2.250 | 0.090 | 0.130 | 0.853 | 2.9 | ||||
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
