Home
Structural and Bar Sections
Flange Beams and Columns
Structural steel beams used for deep foundation applications to add stiffness and support to sheet pile walls and foundations
Designation |
Depth mm |
Width mm |
Thickness Web mm |
Thickness Flange mm |
Sectional Area cm**2 |
Weight kg/m |
Moment of Inertia - Ix cm**4 |
Moment of Inertia - Iy cm**4 |
Section of Modulus - Sx cm**3 |
Section of Modulus - Sy cm**3 |
insert! | HP 200 x 54 | 204 | 207 | 11.3 | 11.3 | 68.4 | 54 | ||||
insert! | HP 250 x 63 | 246 | 257 | 10.5 | 10.7 | 80.0 | 63 | ||||
insert! | HP 250 x 85 | 254 | 259 | 14.4 | 14.4 | 108 | 85 | ||||
insert! | HP 310 x 79 | 300 | 305 | 11.0 | 11.0 | 100 | 79 | ||||
insert! | HP 310 x 94 | 302 | 307 | 13.1 | 13.1 | 119 | 94 | ||||
insert! | HP 310 x 110 | 307 | 310 | 15.4 | 15.5 | 141 | 110 | ||||
insert! | HP 310 x 125 | 312 | 312 | 17.4 | 17.4 | 159 | 125 | ||||
insert! | HP 310 x 132 | 314 | 313 | 18.3 | 18.3 | 167 | 132 | ||||
insert! | HP 310 x 152 | 319 | 321 | 20.8 | 20.8 | 193 | 152 | ||||
insert! | HP 310 x 222 | 324 | 327 | 23.6 | 23.6 | 222 | 174 | ||||
insert! | HP 360 x 109 | 345 | 371 | 12.8 | 12.8 | 138 | 109 | ||||
insert! | HP 360 x 132 | 351 | 373 | 15.6 | 15.6 | 168 | 132 | ||||
insert! | HP 360 x 152 | 356 | 376 | 17.9 | 17.9 | 194 | 152 | ||||
insert! | HP 360 x 174 | 361 | 378 | 20.4 | 20.4 | 222 | 174 | ||||
insert! | HP 410 x 131 | 389 | 399 | 13.7 | 13.7 | 167 | 131 | ||||
insert! | HP 410 x 150 | 394 | 401 | 15.9 | 15.9 | 193 | 150 | ||||
insert! | HP 410 x 180 | 401 | 404 | 19.1 | 19.1 | 231 | 180 | ||||
insert! | HP 410 x 210 | 406 | 406 | 22.2 | 22.2 | 269 | 210 | ||||
insert! | HP 410 x 241 | 414 | 409 | 25.4 | 25.4 | 308 | 241 | ||||
insert! | HP 410 x 272 | 419 | 414 | 28.7 | 28.7 | 349 | 272 | ||||
insert! | HP 460 x 201 | 445 | 452 | 19.1 | 19.1 | 257 | 201 | ||||
insert! | HP 460 x 234 | 450 | 455 | 22.1 | 22.1 | 298 | 234 | ||||
insert! | HP 460 x 269 | 457 | 457 | 25.4 | 25.4 | 343 | 269 | ||||
insert! | HP 460 x 304 | 465 | 460 | 28.7 | 28.7 | 388 | 304 | ||||
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
and more.
5 3
