IPE A medium flange I-Beams according Euronorm 19-57
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | IPE A 140 | 137.4 | 73 | 3.8 | 5.6 | 7 | 13.4 | 10.5 | 434.9 | 36.42 | 63.3 | 9.98 |
| insert! | IPE A 160 | 157 | 82 | 4 | 5.9 | 9 | 16.2 | 12.7 | 689.3 | 54.43 | 87.8 | 13.27 |
| insert! | IPE A 180 | 177 | 91 | 4.3 | 6.5 | 9 | 19.6 | 15.4 | 1063 | 81.89 | 120.1 | 18.00 |
| insert! | IPE A 200 | 197 | 100 | 4.5 | 7 | 12 | 23.5 | 18.4 | 1591 | 117.2 | 161.6 | 23.43 |
| insert! | IPE A 220 | 217 | 110 | 5 | 7.7 | 12 | 28.3 | 22.2 | 2317 | 171.4 | 213.5 | 31.17 |
| insert! | IPE A 240 | 237 | 120 | 5.2 | 8.3 | 15 | 33.3 | 26.2 | 3290 | 277.7 | 277.7 | 40.02 |
| insert! | IPE A 270 | 267 | 135 | 5.5 | 8.7 | 15 | 39.2 | 30.7 | 4917 | 368.3 | 368.3 | 53.03 |
| insert! | IPE A 300 | 297 | 150 | 6.1 | 9.2 | 15 | 46.5 | 36.5 | 7173 | 483.1 | 483.1 | 69.20 |
| insert! | IPE A 330 | 327 | 160 | 6.5 | 10 | 18 | 54.7 | 43.0 | 10230 | 625.7 | 625.7 | 85.64 |
| insert! | IPE A 360 | 357.6 | 170 | 6.6 | 11.5 | 18 | 64.0 | 50.2 | 14520 | 811.8 | 811.8 | 111.1 |
| insert! | IPE A 400 | 397 | 180 | 7 | 12 | 21 | 73.1 | 57.4 | 20290 | 1171 | 1022 | 130.1 |
| insert! | IPE A 450 | 447 | 190 | 7.6 | 13.1 | 21 | 85.6 | 67.2 | 29760 | 1502 | 1331 | 158.1 |
| insert! | IPE A 500 | 497 | 200 | 8.4 | 14.5 | 21 | 101 | 79.4 | 42930 | 1939 | 1728 | 193.9 |
| insert! | IPE A 550 | 547 | 210 | 9 | 15.7 | 24 | 117 | 92.1 | 59980 | 2432 | 2193 | 231.6 |
| custom! | ||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 15
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
