HEA steel beams according DIN 1025 and Euronorm 53-62
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | 100 A | 96 | 100 | 5 | 8 | 12 | 21.2 | 16.7 | 349 | 134 | 72.8 | 26.8 |
| insert! | 120 A | 114 | 120 | 5 | 8 | 12 | 25.3 | 19.9 | 606 | 231 | 106 | 38.5 |
| insert! | 140 A | 133 | 140 | 5.5 | 8.5 | 12 | 31.4 | 24.7 | 1030 | 389 | 155 | 55.6 |
| insert! | 160 A | 152 | 160 | 6 | 9 | 15 | 38.8 | 30.4 | 1670 | 616 | 220 | 76.9 |
| insert! | 180 A | 171 | 180 | 6 | 9.5 | 15 | 45.3 | 35.5 | 2410 | 925 | 294 | 103 |
| insert! | 200 A | 190 | 200 | 6.5 | 10 | 18 | 53.8 | 42.3 | 3690 | 1340 | 389 | 134 |
| insert! | 220 A | 210 | 220 | 7 | 11 | 18 | 64.3 | 50.5 | 5410 | 1950 | 515 | 178 |
| insert! | 240 A | 230 | 240 | 7.5 | 12 | 21 | 76.8 | 60.3 | 7760 | 2770 | 675 | 231 |
| insert! | 260 A | 250 | 260 | 7.5 | 12.5 | 24 | 86.8 | 68.2 | 10450 | 3670 | 836 | 282 |
| insert! | 280 A | 270 | 280 | 8 | 13 | 24 | 97.3 | 76.4 | 13670 | 4760 | 1010 | 340 |
| insert! | 300 A | 290 | 300 | 8.5 | 14 | 27 | 112 | 88.3 | 18260 | 6310 | 1260 | 421 |
| insert! | 320 A | 310 | 300 | 9 | 15.5 | 27 | 124 | 97.6 | 22930 | 6990 | 1480 | 466 |
| insert! | 340 A | 330 | 300 | 9.5 | 16.5 | 27 | 133 | 105 | 27690 | 7440 | 1680 | 496 |
| insert! | 360 A | 350 | 300 | 10 | 17.5 | 27 | 143 | 112 | 33090 | 7890 | 1890 | 526 |
| insert! | 400 A | 390 | 300 | 11 | 19 | 27 | 159 | 125 | 45070 | 8560 | 2310 | 571 |
| insert! | 450 A | 440 | 300 | 11.5 | 21 | 27 | 178 | 140 | 63720 | 9470 | 2900 | 631 |
| insert! | 500 A | 490 | 300 | 12 | 23 | 27 | 198 | 155 | 86970 | 10370 | 3550 | 691 |
| insert! | 550 A | 540 | 300 | 12.5 | 24 | 27 | 212 | 166 | 111900 | 10820 | 4150 | 721 |
| insert! | 600 A | 590 | 300 | 13 | 25 | 27 | 226 | 178 | 141200 | 11270 | 4790 | 751 |
| insert! | 650 A | 640 | 300 | 13.5 | 26 | 27 | 242 | 190 | 175200 | 11720 | 5470 | 782 |
| insert! | 700 A | 690 | 300 | 14.5 | 27 | 27 | 260 | 204 | 215300 | 12180 | 6240 | 812 |
| insert! | 800 A | 790 | 300 | 15 | 28 | 30 | 286 | 224 | 303400 | 12640 | 7680 | 843 |
| insert! | 900 A | 890 | 300 | 16 | 30 | 30 | 321 | 252 | 422100 | 13550 | 9480 | 903 |
| insert! | 1000 A | 990 | 300 | 16.5 | 31 | 30 | 347 | 272 | 553800 | 14000 | 11190 | 934 |
| custom! | ||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 8
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
