Home  > Structural and Bar Sections  > Flange Beams and Columns  >
UB - British Universal Beams
BSI BS 4-1 - Properties of British Universal Beams - Metric Units
ub british universal beam
Designation Depth Width Thickness Web Thickness Flange Root Radius Depth between fillets Sectional Area Weight Moment of Inertia - Ix Moment of Inertia - Iy Section of Modulus - Wx Section of Modulus - Wy
mm mm mm mm mm mm cm**2 kg/m cm**4 cm**4 cm**3 cm**3
insert! UB 127 x 76 x 13 127 76 4 7.6 7.6 96.6 16.5 13 473 55.7 74.6 14.7
insert! UB 152 x 89 x 16 152.4 88.7 4.5 7.7 7.6 121.8 20.3 16 834 89.8 109 20.2
insert! UB 178 x 102 x 19 177.8 101.2 4.8 7.9 7.6 146.8 24.3 19 1356 137 153 27
insert! UB 203 x 102 x 23 203.2 101.8 5.4 9.3 7.6 169.4 29.4 23.1 2105 164 207 32.2
insert! UB 203 x 133 x 25 203.2 133.2 5.7 7.8 7.6 172.4 32 25.1 2340 308 230 46.2
insert! UB 203 x 133 x 30 206.8 133.9 6.4 9.6 7.6 172.4 38.2 30 2896 385 280 57.5
insert! UB 254 x 102 x 22 254 101.6 5.7 6.8 7.6 225.2 28 22 2841 119 224 23.5
insert! UB 254 x 102 x 25 257.2 101.9 6 8.4 7.6 225.2 32 25.2 3415 149 266 29.2
insert! UB 254 x 102 x 28 260.4 102.2 6.3 10 7.6 225.2 36.1 28.3 4005 179 308 34.9
insert! UB 254 x 146 x 31 251.4 146.1 6 8.6 7.6 219 39.7 31.1 4413 448 351 61.3
insert! UB 254 x 146 x 37 256 146.4 6.3 10.9 7.6 219 47.2 37 5537 571 433 78
insert! UB 254 x 146 x 43 259.6 147.3 7.2 12.7 7.6 219 54.8 43 6544 677 504 92
insert! UB 305 x 102 x 25 305.1 101.6 5.8 7 7.6 275.9 31.6 24.8 4455 123 292 24.2
insert! UB 305 x 102 x 28 308.7 101.8 6 8.8 7.6 275.9 35.9 28.2 5366 155 348 30.5
insert! UB 305 x 102 x 33 312.7 102.4 6.6 10.8 7.6 275.9 41.8 32.8 6501 194 416 37.9
insert! UB 305 x 127 x 37 304.4 123.4 7.1 10.7 8.9 265.2 47.2 37 7171 336 471 54.5
insert! UB 305 x 127 x 42 307.2 124.3 8 12.1 8.9 265.2 53.4 41.9 8196 389 534 62.6
insert! UB 305 x 127 x 48 311 125.3 9 14 8.9 265.2 61.2 48.1 9575 461 616 73.6
insert! UB 305 x 165 x 40 303.4 165 6 10.2 8.9 265.2 51.3 40.3 8503 764 560 92.6
insert! UB 305 x 165 x 46 306.6 165.7 6.7 11.8 8.9 265.2 58.7 46.1 9899 896 646 108
insert! UB 305 x 165 x 54 310.4 166.9 7.9 13.7 8.9 265.2 68.8 54 11696 1063 754 127
insert! UB 356 x 127 x 33 349 125.4 6 8.5 10.2 311.6 42.1 33.1 8249 280 473 44.7
insert! UB 356 x 127 x 39 353.4 126 6.6 10.7 10.2 311.6 49.8 39.1 10172 358 576 56.8
insert! UB 356 x 171 x 45 351.4 171.1 7 9.7 10.2 311.6 57.3 45 12066 811 687 94.8
insert! UB 356 x 171 x 51 355 171.5 7.4 11.5 10.2 311.6 64.9 51 14136 968 796 113
insert! UB 356 x 171 x 57 358 172.2 8.1 13 10.2 311.6 72.6 57 16038 1108 896 129
insert! UB 356 x 171 x 67 363.4 173.2 9.1 15.7 10.2 311.6 85.5 67.1 19463 1362 1071 157
insert! UB 406 x 140 x 39 398 141.8 6.4 8.6 10.2 360.4 49.7 39 12508 410 629 57.8
insert! UB 406 x 140 x 46 403.2 142.2 6.8 11.2 10.2 360.4 58.6 46 15685 538 778 75.7
insert! UB 406 x 178 x 54 402.6 177.7 7.7 10.9 10.2 360.4 69 54.1 18722 1021 930 115
insert! UB 406 x 178 x 60 406.4 177.9 7.9 12.8 10.2 360.4 76.5 60.1 21596 1203 1063 135
insert! UB 406 x 178 x 67 409.4 178.8 8.8 14.3 10.2 360.4 85.5 67.1 24331 1365 1189 153
insert! UB 406 x 178 x 74 412.8 179.5 9.5 16 10.2 360.4 94.5 74.2 27310 1545 1323 172
insert! UB 457 x 152 x 52 449.8 152.4 7.6 10.9 10.2 407.6 66.6 52.3 21369 645 950 84.6
insert! UB 457 x 152 x 60 454.6 152.9 8.1 13.3 10.2 407.6 76.2 59.8 25500 795 1122 104
insert! UB 457 x 152 x 67 458 153.8 9 15 10.2 407.6 85.6 67.2 28927 913 1263 119
insert! UB 457 x 152 x 74 462 154.4 9.6 17 10.2 407.6 94.5 74.2 32674 1047 1414 136
insert! UB 457 x 152 x 82 465.8 155.3 10.5 18.9 10.2 407.6 105 82.1 36589 1185 1571 153
insert! UB 457 x 191 x 67 453.4 189.9 8.5 12.7 10.2 407.6 85.5 67.1 29380 1452 1296 153
insert! UB 457 x 191 x 74 457 190.4 9 14.5 10.2 407.6 94.6 74.3 33319 1671 1458 176
insert! UB 457 x 191 x 82 460 191.3 9.9 16 10.2 407.6 104 82 37051 1871 1611 196
insert! UB 457 x 191 x 89 463.4 191.9 10.5 17.7 10.2 407.6 114 89.3 41015 2089 1770 218
insert! UB 457 x 191 x 98 467.2 192.8 11.4 19.6 10.2 407.6 125 98.3 45727 2347 1957 243
insert! UB 533 x 210 x 101 536.7 210 10.8 17.4 12.7 476.5 129 101 61519 2692 2292 256
insert! UB 533 x 210 x 109 539.5 210.8 11.6 18.8 12.7 476.5 139 109 66822 2943 2477 279
insert! UB 533 x 210 x 122 544.5 211.9 12.7 21.3 12.7 476.5 155 122 76043 3388 2793 256
insert! UB 533 x 210 x 82 528.3 208.8 9.6 13.2 12.7 476.5 105 82.2 47539 2007 1800 192
insert! UB 533 x 210 x 92 533.1 209.3 10.1 15.6 12.7 476.5 117 92.1 55227 2389 2072 228
insert! UB 610 x 229 x 101 602.6 227.6 10.5 14.8 12.7 547.6 129 101.2 75780 2915 2515 256
insert! UB 610 x 229 x 113 607.6 228.2 11.1 17.3 12.7 547.6 144 113 87318 3434 2874 301
insert! UB 610 x 229 x 125 612.2 229 11.9 19.6 12.7 547.6 159 125.1 98610 3932 3221 343
insert! UB 610 x 229 x 140 617.2 230.2 13.1 22.1 12.7 547.6 178 139.9 111777 4505 3622 391
insert! UB 610 x 305 x 149 612.4 304.8 11.8 19.7 16.5 540 190 149.2 125876 9308 4111 611
insert! UB 610 x 305 x 179 620.2 307.1 14.1 23.6 16.5 540 228 179 153024 11408 4935 743
insert! UB 610 x 305 x 238 635.8 311.4 18.4 31.4 16.5 540 303 238.1 209471 15837 6589 1017
insert! UB 686 x 254 x 125 677.9 253 11.7 16.2 15.2 615.1 159 125.2 117992 4383 3481 346
insert! UB 686 x 254 x 140 683.5 253.7 12.4 19 15.2 615.1 178 140.1 136267 5183 3987 409
insert! UB 686 x 254 x 152 687.5 254.5 13.2 21 15.2 615.1 194 152.4 150355 5784 4374 455
insert! UB 686 x 254 x 170 692.9 255.8 14.5 23.7 15.2 615.1 217 170.2 170326 6630 4916 518
insert! UB 762 x 267 x 134 750 264.4 12 25.5 16.5 686 171 133.9 150692 4788 4018 362
insert! UB 762 x 267 x 147 754 265.2 12.8 17.5 16.5 686 187 146.9 168502 5455 4470 411
insert! UB 762 x 267 x 173 762.2 266.7 14.3 21.6 16.5 686 220 173 205282 6850 5387 514
insert! UB 762 x 267 x 197 769.8 268 15.6 25.4 16.5 686 251 196.8 239957 8175 6234 610
insert! UB 838 x 292 x 176 834.9 291.7 14 18.8 17.8 761.7 224 175.9 246021 7799 5893 535
insert! UB 838 x 292 x 194 840.7 292.4 14.7 21.7 17.8 761.7 247 193.8 279175 9066 6641 620
insert! UB 838 x 292 x 226 850.9 293.8 16.1 26.8 17.8 761.7 289 226.5 339704 11360 7985 773
insert! UB 914 x 419 x 388 921 420.5 21.4 36.6 24.1 799.6 494 388 719635 45438 15627 2161
insert! UB 914 x 305 x 201 903 303.3 15.1 20.2 19.1 824.4 256 200.9 325254 9423 7204 621
insert! UB 914 x 305 x 224 910.4 304.1 15.9 23.9 19.1 824.4 286 224.2 376414 11236 8269 739
insert! UB 914 x 305 x 253 918.4 305.5 17.3 27.9 19.1 824.4 323 253.4 436305 13301 9501 871
insert! UB 914 x 305 x 289 926.6 307.7 19.5 32 19.1 824.4 368 289.1 504187 15597 10883 1014
insert! UB 914 x 419 x 343 911.8 418.5 19.4 32 24.1 799.6 437 343.3 625780 39156 13726 1871
custom!
Length
Color
Offset
BSI BS 4-1 Structural Steel Sections - Part 1: Specification for Hot-Rolled Sections
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
