Sign in!
Home > Structural Sections > Flange Beams and Columns >
BS 4 - Joists with Taper Flanges
BS 4 part 1: 1993 Joist sections with Taper Flanges
bs 4 joist
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!254 x 203 x 82254203.210.219.919.610582120252280947224
insert!254 x 114 x 37254114.37.612.812.447.337.1508226940047.1
insert!203 x 152 x 52203.2152.48.916.515.566.652.24798816472107
insert!152 x 127 x 37152.412710.413.213.547.537.2181837823959.6
insert!127 x 114 x 29127114.310.211.59.937.429.397924215442.3
insert!127 x 114 x 27127114.37.411.49.934.226.894623614941.3
insert!127 x 76 x 1612776.25.69.69.421.116.557160.89016.0
insert!114 x 114 x 27114.3114.39.510.714.234.527.073622412939.2
insert!102 x 102 x 23101.6101.69.510.311.129.323.048615495.630.3
insert!102 x 44 x 7101.644.54.36.16.99.57.41537.830.13.5
insert!89 x 89 x 1988.988.99.59.911.124.919.530710169.022.8
insert!76 x 76 x 1576.2808.98.49.419.115.017260.945.215.2
insert!76 x 76 x 1376.276.25.18.49.416.212.715851.841.513.6
custom!
Note that the internal profile with root radius and tapered flanges are not drawn. External dimensions are correct.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
