Sign in!
Home > Structural Sections > Flange Beams and Columns >
HE-B - European Steel Beams
HEB steel beams according DIN 1025 and Euronorm 53-62
heb steel beam
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!100 B100100610122620.445016788.933.5
insert!120 B1201206.511123426.786431814452.9
insert!140 B140140712124333.7151055021678.5
insert!160 B1601608131554.342.62490889311111
insert!180 B1801808.5141565.351.238301360426151
insert!200 B2002009151878.161.357002000570200
insert!220 B2202209.516189171.580902840736258
insert!240 B24024010172110683.2112603920938327
insert!260 B2602601017.524118931492051301150395
insert!280 B28028010.518241311031927065901380471
insert!300 B3003001119271491172517085601680571
insert!320 B32030011.520.5271611273082092401930616
insert!340 B3403001221.5271711343666096902160646
insert!360 B36030012.522.52718114243190101402400676
insert!400 B40030013.5242719815557680108202880721
insert!450 B45030014262721817179890117203550781
insert!500 B50030014.52827239187107200126204290842
insert!550 B550300152927254199136700130804970872
insert!600 B60030015.53027270212171000135305700902
insert!650 B650300163127286225210600139806480932
insert!700 B700300173227306241256900144407340963
insert!800 B80030017.53330334262359100149008980994
insert!900 B90030018.5353037129149410015820109801050
insert!1000 B100030019363040031464470016280128901090
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 8
