Properties of BSI BS 4-1 British Universal Columns - Metric Units
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Depth between fillets | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | UC 152 x 152 x 23 | 152.6 | 152.2 | 5.8 | 6.8 | 7.6 | 123.6 | 29.2 | 23 | 1250 | 400 | 164 | 52.6 |
| insert! | UC 152 x 152 x 30 | 157.6 | 152.9 | 6.5 | 9.4 | 7.6 | 123.6 | 38.3 | 30 | 1748 | 560 | 222 | 73.3 |
| insert! | UC 152 x 152 x 37 | 161.8 | 154.4 | 8 | 11.5 | 7.6 | 123.3 | 47.1 | 37 | 2210 | 706 | 273 | 91.5 |
| insert! | UC 203 x 203 x 46 | 203.2 | 203.6 | 7.2 | 11 | 10.2 | 160.8 | 58.7 | 46.1 | 4568 | 1548 | 450 | 152 |
| insert! | UC 203 x 203 x 52 | 206.2 | 204.3 | 7.9 | 12.5 | 10.2 | 160.8 | 66.3 | 52 | 5259 | 1778 | 510 | 174 |
| insert! | UC 203 x 203 x 60 | 209.6 | 205.8 | 9.4 | 14.2 | 10.2 | 160.8 | 76.4 | 60 | 6125 | 2065 | 584 | 201 |
| insert! | UC 203 x 203 x 71 | 215.8 | 206.4 | 10 | 17.3 | 10.2 | 160.8 | 90.4 | 71 | 7618 | 2537 | 706 | 246 |
| insert! | UC 203 x 203 x 86 | 222.2 | 209.1 | 12.7 | 20.5 | 10.2 | 160.8 | 110 | 86 | 9449 | 3127 | 850 | 299 |
| insert! | UC 254 x 254 x 107 | 266.7 | 258.8 | 12.8 | 20.5 | 12.7 | 200.3 | 136 | 107.1 | 17510 | 5928 | 1313 | 458 |
| insert! | UC 254 x 254 x 132 | 276.3 | 261.3 | 15.3 | 25.3 | 12.7 | 200.3 | 168 | 132 | 22529 | 7531 | 1631 | 576 |
| insert! | UC 254 x 254 x 167 | 289.1 | 265.2 | 19.2 | 31.7 | 12.7 | 200.3 | 213 | 167.1 | 29998 | 9870 | 2075 | 744 |
| insert! | UC 254 x 254 x 73 | 254.1 | 254.6 | 8.6 | 14.2 | 12.7 | 200.3 | 93.1 | 73.1 | 11407 | 3908 | 898 | 307 |
| insert! | UC 254 x 254 x 89 | 260.3 | 256.3 | 10.3 | 17.3 | 12.7 | 200.3 | 113 | 88.9 | 14268 | 4857 | 1096 | 379 |
| insert! | UC 305 x 305 x 118 | 314.5 | 307.4 | 12 | 18.7 | 15.2 | 246.7 | 150 | 117.9 | 27672 | 9059 | 1760 | 589 |
| insert! | UC 305 x 305 x 137 | 320.5 | 309.2 | 13.9 | 21.7 | 15.2 | 246.7 | 174 | 3139.97 | 32814 | 10700 | 2048 | 698 |
| insert! | UC 305 x 305 x 158 | 327.1 | 311.2 | 15.8 | 25 | 15.2 | 246.7 | 201 | 158.1 | 38747 | 12569 | 2369 | 808 |
| insert! | UC 305 x 305 x 198 | 339.9 | 314.5 | 19.1 | 31.4 | 15.2 | 246.7 | 252 | 198.1 | 50904 | 16299 | 2995 | 1037 |
| insert! | UC 305 x 305 x 240 | 352.5 | 318.4 | 23 | 37.7 | 15.2 | 246.7 | 306 | 240 | 64203 | 20213 | 3643 | 1246 |
| insert! | UC 305 x 305 x 283 | 365.3 | 322.2 | 26.8 | 44.1 | 15.2 | 246.7 | 360 | 282.9 | 78872 | 24635 | 4318 | 1529 |
| insert! | UC 305 x 305 x 97 | 307.9 | 305.3 | 9.9 | 15.4 | 15.2 | 246.7 | 123 | 96.9 | 22249 | 7308 | 1445 | 479 |
| insert! | UC 356 x 368 x 129 | 355.6 | 368.6 | 10.4 | 17.5 | 15.2 | 290.2 | 164 | 129 | 40246 | 14611 | 2264 | 793 |
| insert! | UC 356 x 368 x 153 | 362 | 370.5 | 12.3 | 20.7 | 15.2 | 290.2 | 195 | 152.9 | 48589 | 17553 | 2684 | 948 |
| insert! | UC 356 x 368 x 177 | 368.2 | 372.6 | 14.4 | 23.8 | 15.2 | 290.2 | 226 | 177 | 57118 | 20529 | 3103 | 1102 |
| insert! | UC 356 x 368 x 202 | 374.6 | 374.7 | 16.5 | 27 | 15.2 | 290.2 | 257 | 201.9 | 66261 | 23688 | 3538 | 1264 |
| insert! | UC 356 x 406 x 235 | 381 | 394.8 | 18.4 | 30.2 | 15.2 | 290.2 | 299 | 235.1 | 79085 | 30993 | 4151 | 1570 |
| insert! | UC 356 x 406 x 287 | 393.6 | 399 | 22.6 | 36.5 | 15.2 | 290.2 | 366 | 287.1 | 99875 | 38677 | 5075 | 1939 |
| insert! | UC 356 x 406 x 340 | 406.4 | 403 | 26.6 | 42.9 | 15.2 | 290.2 | 433 | 339.9 | 122543 | 46853 | 6031 | 2325 |
| insert! | UC 356 x 406 x 393 | 419 | 407 | 30.6 | 49.2 | 15.2 | 290.2 | 501 | 393 | 146618 | 55367 | 6998 | 2721 |
| insert! | UC 356 x 406 x 467 | 436.6 | 412.2 | 35.8 | 58 | 15.2 | 290.2 | 595 | 467 | 183003 | 67834 | 8383 | 3291 |
| insert! | UC 356 x 406 x 551 | 455.6 | 418.5 | 42.1 | 67.5 | 15.2 | 290.2 | 702 | 551 | 226938 | 82671 | 9962 | 3951 |
| insert! | UC 356 x 406 x 634 | 474.6 | 424 | 47.6 | 77 | 15.2 | 290.2 | 808 | 633.9 | 274845 | 98125 | 11582 | 4629 |
| custom! | |||||||||||||
BSI BS 4-1 Structural Steel Sections - Part 1: Specification for Hot-Rolled Sections
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
