Sign in!
Home > Structural Sections > Flange Beams and Columns >
IPE-O - European I Beams
IPE O medium flange I-Beams according Euronorm 19-57
IPE O steel profile
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!IPE O 1801829269927.121.31505117.3189.139.9
insert!IPE O 2002021026.29.51232.025.12211168.9249.451.9
insert!IPE O 2202221126.610.21237.429.43134239.8321.166.9
insert!IPE O 240242122710.81543.734.34369328.5410.384.4
insert!IPE O 2702741367.512.21553.842.36947513.5574.6117.7
insert!IPE O 300304152812.71562.849.39994745.7743.8152.6
insert!IPE O 3303341628.513.51872.657.013910960.4942.8185.0
insert!IPE O 3603641729.214.71884.166.01905012511186226.9
insert!IPE O 4004041829.715.52196.475.72675015641502269.1
insert!IPE O 4504561921117.62111892.44092020852046341.0
insert!IPE O 5005062021219211371075778026222613408.5
insert!IPE O 55055621212.720.2241561237916032243263480.5
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
