Sign in!
Home > Structural Sections > Flange Beams and Columns >
HE-M - European Steel Beams
HEM steel beams according DIN 1025 and Euronorm 53-62
hem steel beam
DesignationDepthWidthThickness WebThickness FlangeRoot RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
mmmmmmmmmmcm**2kg/mcm**4cm**4cm**3cm**3
insert!100 M12010612201253.241.8114039919075.3
insert!120 M14012612.5211266.452.12020703288112
insert!140 M16014613221280.663.232901140411157
insert!160 M18016614231597.176.251001760566212
insert!180 M20018614.5241511388.974802580748277
insert!200 M220206152518131103106403650967354
insert!220 M24022615.526181491171460050101220444
insert!240 M2702481832212001572429081501800657
insert!260 M2902681832.52422017231310104502160780
insert!280 M31028818.5332424018939550131602550914
insert!300 M340310213927303238592001940034801250
insert!320 M359309214027312245681301971038001280
insert!340 M377309214027316248763701971040501280
insert!360 M395308214027319250848701952043001270
insert!400 M4323072140273262561041001933048201260
insert!450 M 4783072140273352631315001934055001260
insert!500 M5243062140273442701619001915061801250
insert!550 M5723062140273542781980001918069201250
insert!600 M6203052140273642852374001897076601240
insert!650 M6683052140273742932817001898084301240
insert!700 M7163042140273833013293001880092001240
insert!800 M81430321403040431744260018530108701230
insert!900 M91030221403042433357040018450125401220
insert!1000 M100830221403044434972230018460143301220
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
