Sign in!
Home > Structural Sections > Flange Beams and Columns >
Aluminum Association Standard I-Beams
Dimensions and Static parameters of Aluminum I-beams - Imperial Units
aluminum i-beam
DesignationDepthWidthThickness WebThickness FlangeFillet RadiusSectional AreaWeightMoment of Inertia - IxMoment of Inertia - IySection of Modulus - WxSection of Modulus - Wy
inininininin**2lb/ftin**4in**4in**3in**3
insert!3 x 2 1/2 x 1.6432.50.130.200.251.391.642.240.521.490.42
insert!3 x 2 1/2 x 2.0332.50.150.260.251.732.032.710.681.810.54
insert!4 x 3 x 2.31430.150.230.251.972.315.621.042.810.69
insert!4 x 3 x 2.79430.170.290.302.382.796.711.313.360.87
insert!5 x 3 1/2 x 3.7053.50.190.320.303.153.7013.92.295.581.31
insert!6 x 4 x 4.03640.190.290.303.434.0322.03.107.331.55
insert!6 x 4 x 4.69640.210.350.303.994.6925.53.748.501.87
insert!7 x 4 1/2 x 5.8074.50.230.380.304.935.8042.95.7812.32.57
insert!8 x 5 x 6.18850.230.350.305.266.1859.77.3014.92.92
insert!8 x 5 x 7.02850.250.410.305.977.0267.88.5516.93.42
insert!9 x 5 1/2 x 8.6395.50.270.440.307.118.6310212.222.74.44
insert!10 x 6 x 8.651060.250.410.407.358.6513214.826.424.93
insert!10 x 6 x 10.291060.290.500.408.7510.2915618.031.26.01
insert!12 x 7 x 11.671270.290.470.409.9311.6725626.942.67.69
insert!12 x 7 x 14.291270.310.620.4012.214.2931735.552.910.1
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 8
