Properties of British Universal bearing piles with wide flanges - Metric Units
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | UBP 203 x 203 x 45 | 200.2 | 205.9 | 9.5 | 9.5 | 10.2 | 57.23 | 44.9 | 4100 | 1384 | 410 | 134 |
| insert! | UBP 203 x 203 x 53.9 | 204 | 207.7 | 11.3 | 11.4 | 10.2 | 68.72 | 53.9 | 5027 | 1705 | 493 | 164 |
| custom! | ||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 21
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
