Cylinders, Boxes, Cones, Planes, Spheres, Lines, Curves and more.
Circular - Spiral Curves -
Add circular or spiral curves to the model
Cone -
Insert a concentric volume to the model.
Cube -
A cube is a three-dimensional solid object bounded by six square faces.
Cylinder - Double Wall -
A double walled cylinder - open in both ends.
Cylinder - Single Wall -
A single walled cylinder - both ends closed.
Line -
A line inserted as a group
Plane - Horizontal -
Horizontal plane with variable thickness
Plane - Vertical -
Vertical planes with variable thickness.
Polygon -
A horizontal surface composed of a finite sequence of straight line segments.
Rectangular Box -
Rectangular box - prism or cuboid
Sphere -
Sphere or ball
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
9 11 7
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
