Home  > Geometric Figures  >
Home  > Function Curves  >
Ellipse
Ellipse - made from parameters
Quadratic Equation - Parabola
An ellipse can be expressed as
x2 / a + y2 / b = 1
Add an ellipse to your Sketchup model with the tool below!
a
b
x diff
Insert!
Length
Color
Offset
"x diff" is a value less than one. Reducing the value increases the number of points in the elliptic curve - more accuracy if you want.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
