Sign in!
Home > Geometric Figures >
Cube
A cube is a three-dimensional solid object bounded by six square faces.
square box
Add a customized cube to your Sketchup model by modifying the parameters below.
Insert!
length of sides
Volume - Surface Area
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 7
