Home  > Geometric Figures  >
Home  > Function Curves  >
Catenary Curve
A Catenery Curve - hanging flexible wire or chain, arch or shape of road
Catenary Curve - hanging flexible wire or chain, arch or shape of road
A catenary curve can be expressed as
x(t) = t
y(t) = 1/2 a (et/a) + e-t/a)
= a cosh(t/a)
start t
end t
no. iterations
a
Insert!
Length
Color
Offset
The Catenary (derived from the latin word foro chain) curve represents the shape of a wire or rope with uniform load supported on both ends. The equation can also be used for design of roads (roulette) and archs.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
