Replicates a custom component around a circle or parts of a circle
First, make a component - a spurs or gear tooth, or a brick or anything you want to replicate around a circle or part of a circle. Position the internal insertion point of the component to where you want the component connected to the circle. Move the component to the Sketchup origo (x = y = z = 0).
Select the component, input the radius of the circle, the number of replications and the degrees of the circle (360 equals to a full circle). Click insert!
Since the same component is replicated as instances around the circle it makes sense to do the final work on the component after the replication. Changes you do in one instance are replicated to all instances.
Note! - select the component to replicate first! Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
