Sign in!
Home > Geometric Figures >
Polygon
A horizontal surface composed of a finite sequence of straight line segments.
polygon surface
Delete, modify or add red and green coordinates for the corners in your polygon in the table below. "Insert!" to add the polygon to your model.
thickness
units
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
