Reload this page!
Home  > Structural and Bar Sections  > Circular Hollow Sections  >
Home  > Geometric Figures  >
Bended Rod
Add a bended rod to your model
bended rod
More segments makes smoother curves.
Bended Rod
inside diameter rod bend:
Insert!
Change before insert!
Add a bended rod to your model with this tool.
Input diameter, center radius and the bended angle of the rod.
Increase the number of segments to increase the smoothness - be aware that increased smoothness will increase the rendering time for the computer.
Only the bended part of the rod is inserted to the model. Extend the ends of the rod by using the native Sketchup push pull tool. (Double click the rod > select the end face > select the push pull tool > pull the rod to required length)
Tools - accessed from within Sketchup
Edit
undo!   redo!
Color
  change color!
View
iso!   top!   front!   right!   left!   back!   bottom!
Make Component
make!
Rotate Object(s)
around red!  , green!   or blue!   axis.
Move or Copy Object(s)
move/copy!
Knife
insert the Knife!   cut!
Move an Object to an other Objects Position
move!
Insert (Reference) Line
  startpoint
  endpoint         insert!
Insert Horizontal Plane
     insert!
Insert Vertical Plane
     insert!
     insert!
Insert Box
     insert!
