Make circles with more (or less) than Sketchup's default 24 segments - add radial lines
By default Sketchup use 24 segments to make a circle. Use the tool below to make circles with more or less segments.
Note that common polygons can be constructed with the tool. A
If required - more segments than the default 24 adds accuracy to the model.
Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
