Home  > Geometric Figures  >
Equilateral Tetrahedron
A three-dimensional figure with four equilateral triangles
A regular tetrahedron has equilateral triangles as its faces.
tetrahedron
Add a customized tetrahedron to your Sketchup model by modifying the parameters below.
Insert!
length of sides
Volume - Surface Area
Length
Color
Offset
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
