Sign in!
Home > Geometric Figures >
Circular - Spiral Curves
Add circular or spiral curves to the model
circular spiral curves
Input the radius, the angle of the curve span (360 equals to a full circle) and the height (zero equals to a flat curve). Heights larger than zero creates spirals.
Input the number of segments. More segments for smoother curves and better approximation to real curve length.
radius
angle
height
number of segments
Summarized Length
of Curve Segments
Insert!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 9
