Home  > Geometric Figures  >
Home  > Function Curves  >
Bezier Curve
Inserts a 4 points Bezier Curve to the Sketchup model
sphere with altitude and longitude lines
Insert a Bezier Curve to the Sketchup model based on four control points.
A four points Bezier curve can be expressed with the equation:
P(i) = P0 (1-i)3 + P1 3 i (1-i)2 + P2 3 i2 (1-t) + P3 i3
where the interval - i - runs from 0 to 1
red green blue
P0 - start point P0
Switch
P1
P1 - control point
P2 - control point P2
Switch
P3
P3 - end point
Insert Bezier Curve from the points above!
Select two control lines in the model
and insert Bezier curve
alt. 1!
alt. 2!
alt. 3!
alt. 4!
Control points of the selected lines!
i - interval (0 - 1)
Length
Color
Offset
The control lines can be removed after insertion.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
