Home
Geometric Figures
Home
Function Curves
Lines - parabolas - made from quadratic equations
The Quadratic Equation can be expressed as
y = ax 2 + bx + c
Add a quadratic curve - a parabola - to your Sketchup model with the tool below!
Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
