Home  > Geometric Figures  >
Home  > Function Curves  >
Lines made from a List of Custom Points
Make a collection of lines based on a list of custom points
sphere with altitude and longitude lines
Add a custom curve to your Sketchup model from a list of points.
Each line in the input text area below represents a point in the line. Modify the list to make your own customized model.
Tip! Make advanced curves from calculations in spreadsheets. Check this example spreadsheet!
  • use a spreadsheet - Excel, Libreoffice, Google Docs or similar
  • calculate a array with the red, green and blue values
  • export or download the spreadsheet to csv format
  • open the csv file in a text editor - Notepad, Textedit or similar
  • range the array with the red, green and blue values
  • copy and paste the values into the input text field below
  • Insert! into your model
red,green,blue
Insert!
Length
Color
Offset
Note! - there may be problems with larger data sets. A workaround is to split larger datasets in smaller chunks. Ungroup and regroup the datasets in the model afterwards if a group is required.
Values from the first example in the example spreadsheet!. Copy and paste into the input field above to test.
0.1,10,0.01
0.2,5,0.04
0.3,3.33333333333333,0.09
0.4,2.5,0.16
0.5,2,0.25
0.6,1.66666666666667,0.36
0.7,1.42857142857143,0.49
0.8,1.25,0.64
0.9,1.11111111111111,0.81
1,1,1
1.1,0.909090909090909,1.21
1.2,0.833333333333333,1.44
1.3,0.769230769230769,1.69
1.4,0.714285714285714,1.96
1.5,0.666666666666666,2.25
1.6,0.625,2.56
1.7,0.588235294117647,2.89
1.8,0.555555555555555,3.24
1.9,0.526315789473684,3.61
2,0.5,4
2.1,0.476190476190476,4.41
2.2,0.454545454545454,4.84
2.3,0.434782608695652,5.29
Values from the second example in the example spreadsheet!. Copy and paste into the input field above to test.
0,1,0
0.2,0.980066577841242,0.198669330795061
0.4,0.921060994002885,0.38941834230865
0.6,0.825335614909678,0.564642473395035
0.8,0.696706709347165,0.717356090899523
1,0.54030230586814,0.841470984807896
1.2,0.362357754476674,0.932039085967226
1.4,0.169967142900241,0.98544972998846
1.6,-0.029199522301289,0.999573603041505
1.8,-0.227202094693087,0.973847630878195
2,-0.416146836547142,0.909297426825682
2.2,-0.588501117255346,0.80849640381959
2.4,-0.737393715541246,0.675463180551151
2.6,-0.856888753368947,0.515501371821464
2.8,-0.942222340668658,0.334988150155905
3,-0.989992496600445,0.141120008059867
3.2,-0.998294775794753,-0.05837414342758
3.4,-0.966798192579461,-0.255541102026831
3.6,-0.896758416334147,-0.442520443294852
3.8,-0.790967711914417,-0.611857890942719
4,-0.653643620863612,-0.756802495307928
4.2,-0.490260821340699,-0.871575772413588
4.4,-0.307332869978419,-0.951602073889516
4.6,-0.112152526935055,-0.993691003633464
4.8,0.087498983439446,-0.996164608835841
5,0.283662185463226,-0.958924274663138
5.2,0.468516671300377,-0.883454655720153
5.4,0.634692875942635,-0.772764487555987
5.6,0.77556587851025,-0.631266637872322
5.8,0.885519516941319,-0.464602179413757
6,0.960170286650366,-0.279415498198926
6.2,0.996542097023218,-0.083089402817496
6.4,0.993184918758193,0.116549204850494
6.6,0.95023259195853,0.311541363513378
6.8,0.869397490349825,0.494113351138608
7,0.753902254343305,0.656986598718789
7.2,0.608351314532254,0.793667863849153
7.4,0.43854732757439,0.898708095811627
7.6,0.251259842582256,0.967919672031486
7.8,0.05395542056265,0.998543345374605
8,-0.145500033808614,0.989358246623382
8.2,-0.339154860983834,0.940730556679773
8.4,-0.519288654116686,0.85459890808828
8.6,-0.678720047320012,0.734397097874114
8.8,-0.811093014061656,0.584917192891762
9,-0.911130261884677,0.412118485241757
9.2,-0.974843621404164,0.222889914100248
9.4,-0.999693042035206,0.024775425453358
9.6,-0.984687855794127,-0.17432678122298
9.8,-0.930426272104753,-0.366479129251928
10,-0.839071529076452,-0.54402111088937
Cartesian Coordinates
This tool can be used to make Cartesian graphs where the red, green and blue axes represents the x, y and z axes in a Cartesian coordinate system. Example with 3 points:
0,0,0
1,1,0
1.2,1.4,0
Area Survey App
Use this online Area Survey App to make an exact plot of a surveyed area - like a room, a property or any 2D shape. The app calculates coordinates for export to the Sktechup Engineering ToolBox Plugin.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
