Reload this page!
Home  > Geometric Figures  >
Grid
Add a grid to your Sketchup model
sphere with altitude and longitude lines
Can be used for construction axes in building projects or similar.
Grid
X Lines
Y Lines
Z Levels
Insert!
Change before insert!
Tools - accessed from within Sketchup
Edit
undo!   redo!
Color
  change color!
View
iso!   top!   front!   right!   left!   back!   bottom!
Make Component
make!
Rotate Object(s)
around red!  , green!   or blue!   axis.
Move or Copy Object(s)
move/copy!
Knife
insert the Knife!   cut!
Move an Object to an other Objects Position
move!
Insert (Reference) Line
  startpoint
  endpoint         insert!
Insert Horizontal Plane
     insert!
Insert Vertical Plane
     insert!
     insert!
Insert Box
     insert!
