Sign in!
Home > Geometric Figures >
Line
A line inserted as a group
line
Insert! green red blue
Length
Use the line as a position assistant or as a starting point for new objects. (PS! The color selector is not working for the line object)
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 7
