Sign in!
Home > Geometric Figures >
Plane - Vertical
Vertical planes with variable thickness.
vertical plane
Insert! height width thickness
Circumference - Area
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 20
