Home  > Geometric Figures  >
Sphere with Longtitude and Latitude Lines
Sphere made of longtitude and latitude lines
sphere with altitude and longitude lines
Longitude Lines
start (degrees)
end (degrees)
difference (degrees)
segments (no.)
Latitude Lines
start (degrees)
end (degrees)
segments (no.)
Radius
radius
Insert!
Volume - Surface Area
Length
Color
Offset
Note!
  • Adjust the start angle and the radius and repeat "Insert!" to make more complicated structures as indicated in the picture below..
  • Select and remove parts of the structure after "Insert!" to make modified objects like segments, half spheres, etc.
  • Experiment with no. of segments (24 is standard for circles in Sketchup) to connect longitudal and latitude crossings.
sphere with altitude and longitude lines examples
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
