Home  > Geometric Figures  >
Home  > Function Curves  >
Exponential Function
Lines made from exponential functions
sphere with altitude and longitude lines
An Exponential Function can be expressed as
y = aex
Add an exponential curve to your Sketchup model with the tool below!
Note! Be careful with the "x end" value. Larger values may exceed Sketchup limits and break your model. Tip! Open a new Sketchup file for testing the values. Copy the curve from the test model to the actual model when you are satisfied.
a
x start
x end
x diff
Insert!
Length
Color
Offset
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
