Parametric stairs and ladders.
Open Stair
- An open stair - top step adaptable to the top floor
Open Stair
- An open stair - top step a part of the stair
Solid Stair
- A solid stair NOTE!! - the insert! and the Tools features only works when the engineeringtoolbox exension is opened from within SketchUp. Install the extension as described in the right column - restart Sketchup and open this tool from the Sketchup Plugins menu.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
