Make your own spiral staircase
| Rise | |
| Rotation (degrees) | |
| Width | |
| no. of steps | |
| thickness of steps | |
| nosing projection | |
Unit rise Elevation angle deg | |
| Insert into SketchUp! | |
Tip! Use the vertical and horizontal planes to position the stair - remove the planes after insertion.
Add handrails and details for the stair by selecting and working on one step (all steps are instances of the same components).
A larger inside radius can be achieved by using a larger width - modifying the unit step after insertion.
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 21
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
