Sign in!
Home > Stairs and Ladders >
Open Stair
An open stair - top step adaptable to the top floor.
stair
Rise
Run
Width
no. of steps
thickness of steps
nosing projection
Unit rise
Unit run
Elevation angle deg
Insert into SketchUp!
Tip! Use the vertical and horizontal planes to position the stair - remove the planes after insertion.
stair
Add handrails and details for the stair by selecting and working on one step (all steps are instances of the same components).
Select the top step and make it unique before adapting it to the top floor.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 7
