Sign in!
Home > Stairs and Ladders >
Solid Stair
A solid stair
stair
Rise
Run
Width
no. of steps
nosing projection
Unit rise
Unit run
Elevation angle deg
Insert into SketchUp!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 8
