Combine flanges and pipes
Sorry! - but due to virtually unlimited variations there are no premade valves available in the Engineering ToolBox.
Parameters like
influences the model of the valve and makes it a hard job to make standard libraries.
The possible most efficient ways to add valves using the Engineering ToolBox:
Insert a flange of the right type, size and pressure rating to your model, copy the flange, turn the copy (use the Rotate Object below) and move it to the right distance from the first flange according the specification from the valve supplier. Select the two flanges and make them a component. Name the component according the valve specification.
In addition - if you want - insert a pipe between the to flanges, add a handle, a motor or any of the other details you find necessary.
Insert a pipe with the right dimension and length according the specification from the valve supplier. Select the pipe and make it a component. Name the component according the valve specification.
In addition - if you want - add a handle, a motor or any of the other details you find necessary.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
