Square Hollow Sections - Hot Formed .. BS EN 10219:1997 - Metric Units
| Designation | Width | Depth | Thickness | Ext. Corner Radii | Int. Corner Radii | Mass | Area of Section | Second Moment of Area | |
| mm | mm | mm | mm | mm | kg/m | cm**2 | cm**4 | ||
| insert! | SHS 20 x 2 | 20 | 20 | 2.0 | 3 | 2 | 1.1 | 1.4 | 0.739 |
| insert! | SHS 20 x 2.5 | 20 | 20 | 2.5 | 3.75 | 2.5 | 1.32 | 1.68 | 0.835 |
| insert! | SHS 25 x 2 | 25 | 25 | 2.0 | 3 | 2 | 1.41 | 1.8 | 1.56 |
| insert! | SHS 25 x 2.5 | 25 | 25 | 2.5 | 3.75 | 2.5 | 1.71 | 2.18 | 1.81 |
| insert! | SHS 25 x 3 | 25 | 25 | 3.0 | 4.5 | 3 | 2 | 2.54 | 2 |
| insert! | SHS 30 x 2 | 30 | 30 | 2.0 | 3 | 2 | 1.72 | 2.2 | 2.84 |
| insert! | SHS 30 x 2.5 | 30 | 30 | 2.5 | 3.75 | 2.5 | 2.11 | 2.68 | 3.33 |
| insert! | SHS 30 x 3 | 30 | 30 | 3.0 | 4.5 | 3 | 2.47 | 3.14 | 3.74 |
| insert! | SHS 40 x 2.5 | 40 | 40 | 2.5 | 3.75 | 2.5 | 2.89 | 3.68 | 8.54 |
| insert! | SHS 40 x 3 | 40 | 40 | 3.0 | 4.5 | 3 | 3.41 | 4.34 | 9.78 |
| insert! | SHS 40 x 3.2 | 40 | 40 | 3.2 | 4.8 | 3.2 | 3.61 | 4.6 | 10.2 |
| insert! | SHS 40 x 3.6 | 40 | 40 | 3.6 | 5.4 | 3.6 | 4.01 | 5.1 | 11.1 |
| insert! | SHS 40 x 4 | 40 | 40 | 4.0 | 6 | 4 | 4.39 | 5.59 | 11.8 |
| insert! | SHS 40 x 5 | 40 | 40 | 5.0 | 7.5 | 5 | 5.28 | 6.73 | 13.4 |
| insert! | SHS 50 x 2.5 | 50 | 50 | 2.5 | 3.75 | 2.5 | 3.68 | 4.68 | 17.5 |
| insert! | SHS 50 x 3 | 50 | 50 | 3.0 | 4.5 | 3 | 4.35 | 5.54 | 20.2 |
| insert! | SHS 50 x 3.2 | 50 | 50 | 3.2 | 4.8 | 3.2 | 4.62 | 5.88 | 21.2 |
| insert! | SHS 50 x 3.6 | 50 | 50 | 3.6 | 5.4 | 3.6 | 5.14 | 6.54 | 23.2 |
| insert! | SHS 50 x 4 | 50 | 50 | 4.0 | 6 | 4 | 5.64 | 7.19 | 25 |
| insert! | SHS 50 x 5 | 50 | 50 | 5.0 | 7.5 | 5 | 6.85 | 8.73 | 28.9 |
| insert! | SHS 50 x 6 | 50 | 50 | 6.0 | 9 | 6 | 7.99 | 10.2 | 32 |
| insert! | SHS 50 x 6.3 | 50 | 50 | 6.3 | 9.45 | 6.3 | 8.31 | 10.6 | 32.8 |
| insert! | SHS 60 x 2.5 | 60 | 60 | 2.5 | 3.75 | 2.5 | 4.46 | 5.68 | 31.1 |
| insert! | SHS 60 x 3 | 60 | 60 | 3.0 | 4.5 | 3 | 5.29 | 6.74 | 36.2 |
| insert! | SHS 60 x 3.2 | 60 | 60 | 3.2 | 4.8 | 3.2 | 5.62 | 7.16 | 38.2 |
| insert! | SHS 60 x 3.6 | 60 | 60 | 3.6 | 5.4 | 3.6 | 6.27 | 7.98 | 41.9 |
| insert! | SHS 60 x 4 | 60 | 60 | 4.0 | 6 | 4 | 6.9 | 8.79 | 45.4 |
| insert! | SHS 60 x 5 | 60 | 60 | 5.0 | 7.5 | 5 | 8.42 | 10.7 | 53.3 |
| insert! | SHS 60 x 6 | 60 | 60 | 6.0 | 6 | 9.87 | 12.6 | 59.9 | |
| insert! | SHS 60 x 6.3 | 60 | 60 | 6.3 | 9.45 | 6.3 | 10.3 | 13.1 | 61.6 |
| insert! | SHS 60 x 8 | 60 | 60 | 8.0 | 12 | 8 | 12.5 | 16 | 69.7 |
| insert! | SHS 70 x 3 | 70 | 70 | 3.0 | 4.5 | 3 | 6.24 | 7.94 | 59 |
| insert! | SHS 70 x 3.2 | 70 | 70 | 3.2 | 4.8 | 3.2 | 6.63 | 8.44 | 62.3 |
| insert! | SHS 70 x 3.6 | 70 | 70 | 3.6 | 5.4 | 3.6 | 7.4 | 9.42 | 68.6 |
| insert! | SHS 70 x 4 | 70 | 70 | 4.0 | 6 | 4 | 8.15 | 10.4 | 74.7 |
| insert! | SHS 70 x 5 | 70 | 70 | 5.0 | 7.5 | 5 | 9.99 | 12.7 | 88.5 |
| insert! | SHS 70 x 6 | 70 | 70 | 6.0 | 9 | 6 | 11.8 | 15 | 101 |
| insert! | SHS 70 x 6.3 | 70 | 70 | 6.3 | 9.45 | 6.3 | 12.3 | 15.6 | 104 |
| insert! | SHS 70 x 8 | 70 | 70 | 8.0 | 12 | 8 | 15 | 19.2 | 120 |
| insert! | SHS 80 x 3 | 80 | 80 | 3.0 | 4.5 | 3 | 7.18 | 9.14 | 89.8 |
| insert! | SHS 80 x 3.2 | 80 | 80 | 3.2 | 4.8 | 3.2 | 7.63 | 9.72 | 95 |
| insert! | SHS 80 x 3.6 | 80 | 80 | 3.6 | 5.4 | 3.6 | 8.53 | 10.9 | 105 |
| insert! | SHS 80 x 4 | 80 | 80 | 4.0 | 6 | 4 | 9.41 | 12 | 114 |
| insert! | SHS 80 x 5 | 80 | 80 | 5.0 | 7.5 | 5 | 11.6 | 14.7 | 137 |
| insert! | SHS 80 x 6 | 80 | 80 | 6.0 | 9 | 6 | 13.6 | 17.4 | 156 |
| insert! | SHS 80 x 6.3 | 80 | 80 | 6.3 | 9.45 | 6.3 | 14.2 | 18.1 | 162 |
| insert! | SHS 80 x 8 | 80 | 80 | 8.0 | 12 | 8 | 1.5 | 22.4 | 189 |
| insert! | SHS 90 x 5 | 90 | 90 | 5.0 | 7.5 | 5 | 13.1 | 16.7 | 200 |
| insert! | SHS 90 x 6 | 90 | 90 | 6.0 | 9 | 6 | 15.5 | 19.8 | 230 |
| insert! | SHS 90 x 6.3 | 90 | 90 | 6.3 | 9.45 | 6.3 | 16.2 | 20.7 | 238 |
| insert! | SHS 90 x 8 | 90 | 90 | 8.0 | 12 | 8 | 20.1 | 25.6 | 281 |
| insert! | SHS 100 x 3.6 | 100 | 100 | 3.6 | 5.4 | 3.6 | 10.8 | 13.7 | 212 |
| insert! | SHS 100 x 4 | 100 | 100 | 4.0 | 6 | 4 | 11.9 | 15.2 | 232 |
| insert! | SHS 100 x 5 | 100 | 100 | 5.0 | 7.5 | 5 | 14.7 | 18.7 | 279 |
| insert! | SHS 100 x 6 | 100 | 100 | 6.0 | 9 | 6 | 17.4 | 22.2 | 323 |
| insert! | SHS 100 x 6.3 | 100 | 100 | 6.3 | 9.45 | 6.3 | 18.2 | 23.2 | 336 |
| insert! | SHS 100 x 8 | 100 | 100 | 8.0 | 12 | 8 | 22.6 | 28.8 | 400 |
| insert! | SHS 100 x 10 | 100 | 100 | 10.0 | 15 | 10 | 27.4 | 34.9 | 462 |
| insert! | SHS 120 x 4 | 120 | 120 | 4.0 | 6 | 4 | 14.4 | 18.4 | 410 |
| insert! | SHS 120 x 5 | 120 | 120 | 5.0 | 7.5 | 5 | 1.8 | 22.7 | 498 |
| insert! | SHS 120 x 6 | 120 | 120 | 6.0 | 9 | 6 | 21.2 | 27 | 579 |
| insert! | SHS 120 x 6.3 | 120 | 120 | 6.3 | 9.45 | 6.3 | 22.2 | 28.2 | 603 |
| insert! | SHS 120 x 8 | 120 | 120 | 8.0 | 12 | 8 | 27.6 | 35.2 | 726 |
| insert! | SHS 120 x 10 | 120 | 120 | 10.0 | 15 | 10 | 33.7 | 42.9 | 852 |
| insert! | SHS 120 x 12 | 120 | 120 | 12.0 | 18 | 12 | 39.5 | 50.3 | 958 |
| insert! | SHS 120 x 12.5 | 120 | 120 | 12.5 | 18.75 | 12.5 | 40.9 | 52.1 | 982 |
| insert! | SHS 140 x 5 | 140 | 140 | 5.0 | 7.5 | 5 | 21 | 26.7 | 807 |
| insert! | SHS 140 x 6 | 140 | 140 | 6.0 | 9 | 6 | 24.9 | 31.8 | 944 |
| insert! | SHS 140 x 6.3 | 140 | 140 | 6.3 | 9.45 | 6.3 | 26.1 | 33.3 | 984 |
| insert! | SHS 140 x 8 | 140 | 140 | 8.0 | 12 | 8 | 32.6 | 41.6 | 1195 |
| insert! | SHS 140 x 10 | 140 | 140 | 10.0 | 15 | 10 | 40 | 50.9 | 1416 |
| insert! | SHS 140 x 12 | 140 | 140 | 12.0 | 18 | 12 | 47 | 59.9 | 1609 |
| insert! | SHS 140 x 12.5 | 140 | 140 | 12.5 | 18.75 | 12.5 | 48.7 | 62.1 | 1653 |
| insert! | SHS 150 x 5 | 150 | 150 | 5.0 | 7.5 | 5 | 22.6 | 28.7 | 1002 |
| insert! | SHS 150 x 6 | 150 | 150 | 6.0 | 9 | 6 | 26.8 | 34.2 | 1174 |
| insert! | SHS 150 x 6.3 | 150 | 150 | 6.3 | 9.45 | 6.3 | 28.1 | 35.8 | 1223 |
| insert! | SHS 150 x 8 | 150 | 150 | 8.0 | 12 | 8 | 35.1 | 44.8 | 1491 |
| insert! | SHS 150 x 10 | 150 | 150 | 10.0 | 15 | 10 | 43.1 | 54.9 | 1773 |
| insert! | SHS 150 x 12 | 150 | 150 | 12.0 | 18 | 12 | 50.8 | 64.7 | 2023 |
| insert! | SHS 150 x 12.5 | 150 | 150 | 12.5 | 18.75 | 12.5 | 52.7 | 67.1 | 2080 |
| insert! | SHS 150 x 16 | 150 | 150 | 16.0 | 24 | 16 | 65.2 | 83 | 2430 |
| insert! | SHS 160 x 5 | 160 | 160 | 5.0 | 7.5 | 5 | 24.1 | 30.7 | 1225 |
| insert! | SHS 160 x 6 | 160 | 160 | 6.0 | 9 | 6 | 28.7 | 36.6 | 1437 |
| insert! | SHS 160 x 6.3 | 160 | 160 | 6.3 | 9.45 | 6.3 | 30.1 | 38.3 | 1499 |
| insert! | SHS 160 x 8 | 160 | 160 | 8.0 | 12 | 8 | 37.6 | 48 | 1831 |
| insert! | SHS 160 x 10 | 160 | 160 | 10.0 | 15 | 10 | 46.3 | 58.9 | 2186 |
| insert! | SHS 160 x 12 | 160 | 160 | 12.0 | 18 | 12 | 54.6 | 69.5 | 2502 |
| insert! | SHS 160 x 12.5 | 160 | 160 | 12.5 | 18.75 | 12.5 | 56.6 | 72 | 2576 |
| insert! | SHS 160 x 16 | 160 | 160 | 16.0 | 24 | 16 | 70.2 | 89.4 | 3028 |
| insert! | SHS 180 x 5 | 180 | 180 | 5.0 | 7.5 | 5 | 27.3 | 34.7 | 1765 |
| insert! | SHS 180 x 6 | 180 | 180 | 6.0 | 9 | 6 | 32.5 | 41.4 | 2077 |
| insert! | SHS 180 x 6.3 | 180 | 180 | 6.3 | 9.45 | 6.3 | 34 | 43.3 | 2168 |
| insert! | SHS 180 x 8 | 180 | 180 | 8.0 | 12 | 8 | 42.7 | 54.4 | 2661 |
| insert! | SHS 180 x 10 | 180 | 180 | 10.0 | 15 | 10 | 52.5 | 66.9 | 3193 |
| insert! | SHS 180 x 12 | 180 | 180 | 12.0 | 18 | 12 | 62.1 | 79.1 | 3677 |
| insert! | SHS 180 x 12.5 | 180 | 180 | 12.5 | 18.75 | 12.5 | 64.4 | 82.1 | 3790 |
| insert! | SHS 180 x 16 | 180 | 180 | 16.0 | 24 | 16 | 80.2 | 102 | 4504 |
| insert! | SHS 200 x 5 | 200 | 200 | 5.0 | 7.5 | 5 | 30.4 | 38.7 | 2445 |
| insert! | SHS 200 x 6 | 200 | 200 | 6.0 | 9 | 6 | 36.2 | 46.2 | 2883 |
| insert! | SHS 200 x 6.3 | 200 | 200 | 6.3 | 9.45 | 6.3 | 38 | 48.4 | 3011 |
| insert! | SHS 200 x 8 | 200 | 200 | 8.0 | 12 | 8 | 47.7 | 60.8 | 3709 |
| insert! | SHS 200 x 10 | 200 | 200 | 10.0 | 15 | 10 | 58.8 | 74.9 | 4471 |
| insert! | SHS 200 x 12 | 200 | 200 | 12.0 | 18 | 12 | 69.6 | 88.7 | 5171 |
| insert! | SHS 200 x 12.5 | 200 | 200 | 12.5 | 18.75 | 12.5 | 72.3 | 92.1 | 5336 |
| insert! | SHS 200 x 16 | 200 | 200 | 16.0 | 24 | 16 | 90.3 | 115 | 6394 |
| insert! | SHS 220 x 6 | 220 | 220 | 6.0 | 9 | 6 | 40 | 51 | 3875 |
| insert! | SHS 220 x 6.3 | 220 | 220 | 6.3 | 9.45 | 6.3 | 41.9 | 53.4 | 4049 |
| insert! | SHS 220 x 8 | 220 | 220 | 8.0 | 12 | 8 | 52.7 | 67.2 | 5002 |
| insert! | SHS 220 x 10 | 220 | 220 | 10.0 | 15 | 10 | 65.1 | 82.9 | 6050 |
| insert! | SHS 220 x 12 | 220 | 220 | 12.0 | 18 | 12 | 77.2 | 98.3 | 7023 |
| insert! | SHS 220 x 12.5 | 220 | 220 | 12.5 | 18.75 | 12.5 | 80.1 | 102 | 7254 |
| insert! | SHS 220 x 16 | 220 | 220 | 16.0 | 24 | 16 | 100 | 128 | 8749 |
| insert! | SHS 250 x 5 | 250 | 250 | 5.0 | 7.5 | 5 | 38.3 | 48.7 | 4861 |
| insert! | SHS 250 x 6 | 250 | 250 | 6.0 | 9 | 6 | 45.7 | 58.2 | 5752 |
| insert! | SHS 250 x 6.3 | 250 | 250 | 6.3 | 9.45 | 6.3 | 47.9 | 61 | 6014 |
| insert! | SHS 250 x 8 | 250 | 250 | 8.0 | 12 | 8 | 60.3 | 76.8 | 7455 |
| insert! | SHS 250 x 10 | 250 | 250 | 10.0 | 15 | 10 | 74.5 | 94.9 | 9055 |
| insert! | SHS 250 x 12 | 250 | 250 | 12.0 | 18 | 12 | 88.5 | 113 | 10556 |
| insert! | SHS 250 x 12.5 | 250 | 250 | 12.5 | 18.75 | 12.5 | 91.9 | 117 | 10915 |
| insert! | SHS 250 x 16 | 250 | 250 | 16.0 | 24 | 16 | 115 | 147 | 13267 |
| insert! | SHS 260 x 6 | 260 | 260 | 6.0 | 9 | 6 | 47.6 | 60.6 | 6491 |
| insert! | SHS 260 x 6.3 | 260 | 260 | 6.3 | 9.45 | 6.3 | 49.9 | 63.5 | 6788 |
| insert! | SHS 260 x 8 | 260 | 260 | 8.0 | 12 | 8 | 62.8 | 80 | 8423 |
| insert! | SHS 260 x 10 | 260 | 260 | 10.0 | 15 | 10 | 77.7 | 98.9 | 10242 |
| insert! | SHS 260 x 12 | 260 | 260 | 12.0 | 18 | 12 | 92.2 | 117 | 11954 |
| insert! | SHS 260 x 12.5 | 260 | 260 | 12.5 | 18.75 | 12.5 | 95.8 | 122 | 12365 |
| insert! | SHS 260 x 16 | 260 | 260 | 16.0 | 24 | 16 | 120 | 153 | 15061 |
| insert! | SHS 300 x 6 | 300 | 300 | 6.0 | 9 | 6 | 55.1 | 70.2 | 10080 |
| insert! | SHS 300 x 6.3 | 300 | 300 | 6.3 | 9.45 | 6.3 | 57.8 | 73.6 | 10547 |
| insert! | SHS 300 x 8 | 300 | 300 | 8.0 | 12 | 8 | 72.8 | 92.8 | 13128 |
| insert! | SHS 300 x 10 | 300 | 300 | 10.0 | 15 | 10 | 90.2 | 115 | 16026 |
| insert! | SHS 300 x 12 | 300 | 300 | 12.0 | 18 | 12 | 107 | 137 | 18777 |
| insert! | SHS 300 x 12.5 | 300 | 300 | 12.5 | 18.75 | 12.5 | 112 | 142 | 19442 |
| insert! | SHS 300 x 16 | 300 | 300 | 16.0 | 24 | 16 | 141 | 179 | 23850 |
| insert! | SHS 350 x 8 | 350 | 350 | 8.0 | 12 | 8 | 85.4 | 109 | 21129 |
| insert! | SHS 350 x 10 | 350 | 350 | 10.0 | 15 | 10 | 106 | 135 | 25884 |
| insert! | SHS 350 x 12 | 350 | 350 | 12.0 | 18 | 12 | 126 | 161 | 30435 |
| insert! | SHS 350 x 12.5 | 350 | 350 | 12.5 | 18.75 | 12.5 | 131 | 167 | 31541 |
| insert! | SHS 350 x 16 | 350 | 350 | 16.0 | 24 | 16 | 166 | 211 | 38942 |
| insert! | SHS 400 x 8 | 400 | 400 | 8.0 | 12 | 8 | 97.9 | 125 | 31857 |
| insert! | SHS 400 x 10 | 400 | 400 | 10.0 | 15 | 10 | 122 | 155 | 39128 |
| insert! | SHS 400 x 12 | 400 | 400 | 12.0 | 18 | 12 | 145 | 185 | 46130 |
| insert! | SHS 400 x 12.5 | 400 | 400 | 12.5 | 18.75 | 12.5 | 151 | 192 | 47839 |
| insert! | SHS 400 x 16 | 400 | 400 | 16.0 | 24 | 16 | 191 | 243 | 59344 |
| insert! | SHS 400 x 20 | 400 | 400 | 20.0 | 30 | 20 | 235 | 300 | 71535 |
| custom! | |||||||||
Note that rounded corners are not drawn. It makes moving and positioning the sections easier.
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 3
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
