Home
Structural and Bar Sections
Tee Sections
BS 4 part 1: 1993 Tee sections cut from Universal Beams
Designation |
Depth mm |
Width mm |
Thickness Web mm |
Thickness Flange mm |
Root Radius mm |
Sectional Area cm**2 |
Weight kg/m |
Moment of Inertia - Ix cm**4 |
Moment of Inertia - Iy cm**4 |
Section of Modulus - Sx cm**3 |
Section of Modulus - Sy cm**3 |
| insert! | 305 x 457 x 127 | 459.1 | 305.5 | 17.3 | 27.9 | 19.1 | 161 | 126.7 | 32698 | 6651 | 2720 | 435 |
| insert! | 305 x 457 x 112 | 455.1 | 304.1 | 15.9 | 23.9 | 19.1 | 143 | 112.1 | 29063 | 5618 | 2395 | 369 |
| insert! | 305 x 457 x 101 | 451.4 | 303.3 | 15.1 | 20.2 | 19.1 | 128 | 100.4 | 26350 | 4711 | 2106 | 311 |
| insert! | 292 x 419 x 113 | 425.4 | 293.8 | 16.1 | 26.8 | 17.8 | 144 | 113.3 | 24622 | 5680 | 2276 | 387 |
| insert! | 292 x 419 x 97 | 420.3 | 292.4 | 14.7 | 21.7 | 17.8 | 123 | 96.9 | 21336 | 4533 | 1926 | 310 |
| insert! | 292 x 419 x 88 | 417.4 | 291.7 | 14 | 18.8 | 17.8 | 112 | 87.9 | 19565 | 3899 | 1723 | 267 |
| insert! | 267 x 381 x 99 | 384.8 | 268 | 15.6 | 25.4 | 16.5 | 125 | 98.4 | 17510 | 4087 | 1770 | 305 |
| insert! | 267 x 381 x 87 | 381 | 266.7 | 14.3 | 21.6 | 16.5 | 110 | 86.5 | 15477 | 3425 | 1550 | 257 |
| insert! | 267 x 381 x 74 | 376.9 | 265.2 | 12.8 | 17.5 | 16.5 | 93.6 | 73.5 | 13245 | 2728 | 1304 | 206 |
| insert! | 254 x 343 x 85 | 346.4 | 255.8 | 14.5 | 23.7 | 15.2 | 108 | 85.1 | 12047 | 3315 | 1389 | 259 |
| insert! | 254 x 343 x 76 | 343.7 | 254.5 | 13.2 | 21.0 | 15.2 | 97 | 76.2 | 10755 | 2892 | 1249 | 227 |
| insert! | 254 x 343 x 70 | 341.7 | 253.7 | 12.4 | 19.0 | 15.2 | 89.2 | 70 | 9910 | 2592 | 1149 | 204 |
| insert! | 254 x 343 x 63 | 338.9 | 253 | 11.7 | 16.2 | 15.2 | 79.7 | 62.6 | 8976 | 2191 | 1014 | 173 |
| insert! | 305 x 305 x 119 | 317.8 | 311.4 | 18.4 | 31.4 | 16.5 | 152 | 119 | 12344 | 7918 | 1737 | 509 |
| insert! | 305 x 305 x 90 | 310 | 307.1 | 14.1 | 23.6 | 16.5 | 114 | 89.5 | 9043 | 5704 | 1353 | 371 |
| insert! | 305 x 305 x 75 | 306.1 | 304.8 | 11.8 | 19.7 | 16.5 | 95 | 74.6 | 7415 | 4654 | 1150 | 305 |
| insert! | 229 x 305 x 70 | 308.8 | 230.2 | 13.1 | 22.1 | 12.7 | 89.1 | 69.9 | 7741 | 2253 | 1017 | 196 |
| insert! | 229 x 305 x 63 | 306 | 229 | 11.9 | 19.6 | 12.7 | 79.7 | 62.5 | 6898 | 1966 | 915 | 172 |
| insert! | 229 x 305 x 57 | 303.7 | 228.2 | 11.1 | 17.3 | 12.7 | 72 | 56.5 | 6265 | 1717 | 826 | 150 |
| insert! | 229 x 305 x 51 | 301.2 | 227.6 | 10.5 | 14.8 | 12.7 | 64.4 | 50.6 | 5691 | 1457 | 732 | 128 |
| insert! | 210 x 267 x 61 | 272.2 | 211.9 | 12.7 | 21.3 | 12.7 | 77.7 | 61.0 | 5161 | 1694 | 775 | 160 |
| insert! | 210 x 267 x 55 | 269.7 | 210.8 | 11.6 | 18.8 | 12.7 | 69.4 | 54.5 | 4604 | 1471 | 697 | 140 |
| insert! | 210 x 267 x 51 | 268.3 | 210 | 10.8 | 17.4 | 12.7 | 64.3 | 50.5 | 4245 | 1346 | 650 | 128 |
| insert! | 210 x 267 x 46 | 266.5 | 209.3 | 10.1 | 15.6 | 12.7 | 58.7 | 46.1 | 3885 | 1195 | 593 | 114 |
| insert! | 210 x 267 x 41 | 264.1 | 208.8 | 9.6 | 13.2 | 12.7 | 52.3 | 41.1 | 3527 | 1004 | 523 | 96.1 |
| insert! | 191 x 229 x 49 | 233.5 | 192.8 | 11.4 | 19.6 | 10.2 | 62.6 | 49.2 | 2967 | 1174 | 536 | 122 |
| insert! | 191 x 229 x 45 | 231.6 | 191.9 | 10.5 | 17.7 | 10.2 | 56.9 | 44.6 | 2684 | 1045 | 491 | 109 |
| insert! | 191 x 229 x 41 | 229.9 | 191.3 | 9.9 | 16.0 | 10.2 | 52.2 | 41.0 | 2474 | 935 | 452 | 97.8 |
| insert! | 191 x 229 x 37 | 228.4 | 190.4 | 9 | 14.5 | 10.2 | 47.3 | 37.1 | 2224 | 836 | 413 | 87.8 |
| insert! | 191 x 229 x 34 | 226.6 | 189.9 | 8.5 | 12.7 | 10.2 | 42.2 | 33.6 | 2034 | 726 | 372 | 76.5 |
| insert! | 152 x 229 x 41 | 232.8 | 155.3 | 10.5 | 18.9 | 10.2 | 52.3 | 41.0 | 2596 | 592 | 436 | 76.3 |
| insert! | 152 x 229 x 37 | 230.9 | 154.4 | 9.6 | 17.0 | 10.2 | 47.2 | 37.1 | 2332 | 523 | 397 | 67.8 |
| insert! | 152 x 229 x 34 | 228.9 | 153.8 | 9 | 15.0 | 10.2 | 42.8 | 33.6 | 2121 | 456 | 359 | 59.3 |
| insert! | 152 x 229 x 30 | 227.2 | 152.9 | 8.1 | 13.3 | 10.2 | 38.1 | 29.9 | 1879 | 397 | 322 | 52.0 |
| insert! | 152 x 229 x 26 | 224.8 | 152.4 | 7.6 | 10.9 | 10.2 | 33.3 | 26.2 | 1670 | 322 | 276 | 42.3 |
| insert! | 178 x 203 x 37 | 206.3 | 179.5 | 9.5 | 16.0 | 10.2 | 47.2 | 37.1 | 1736 | 773 | 365 | 86.1 |
| insert! | 178 x 203 x 34 | 204.6 | 178.8 | 8.8 | 14.3 | 10.2 | 42.8 | 33.6 | 1573 | 682 | 332 | 76.3 |
| insert! | 178 x 203 x 30 | 203.1 | 177.9 | 7.9 | 12.8 | 10.2 | 38.3 | 30.0 | 1395 | 602 | 301 | 67.6 |
| insert! | 178 x 203 x 27 | 201.2 | 177.7 | 7.7 | 10.9 | 10.2 | 34.5 | 27.1 | 1294 | 511 | 268 | 57.5 |
| insert! | 140 x 203 x 23 | 201.5 | 142.2 | 6.8 | 11.2 | 10.2 | 29.3 | 23.0 | 1123 | 269 | 224 | 37.8 |
| insert! | 140 x 203 x 20 | 198.9 | 141.8 | 6.4 | 8.6 | 10.2 | 24.8 | 19.5 | 979 | 205 | 184 | 28.9 |
| insert! | 171 x 178 x 34 | 181.6 | 173.2 | 9.1 | 15.7 | 10.2 | 42.7 | 33.5 | 1154 | 681 | 288 | 78.6 |
| insert! | 171 x 178 x 29 | 178.9 | 172.2 | 8.1 | 13.0 | 10.2 | 36.3 | 28.5 | 986 | 554 | 248 | 64.4 |
| insert! | 171 x 178 x 26 | 177.4 | 171.5 | 7.4 | 11.5 | 10.2 | 32.4 | 25.5 | 882 | 484 | 224 | 56.5 |
| insert! | 171 x 178 x 23 | 175.6 | 171.1 | 7.0 | 9.7 | 10.2 | 28.7 | 22.5 | 798 | 406 | 197 | 47.4 |
| insert! | 127 x 178 x 20 | 176.6 | 126 | 6.6 | 10.7 | 10.2 | 24.9 | 19.5 | 728 | 179 | 164 | 28.4 |
| insert! | 127 x 178 x 17 | 174.4 | 125.4 | 6.0 | 8.5 | 10.2 | 21.1 | 16.5 | 626 | 140 | 137 | 22.3 |
| insert! | 165 x 152 x 27 | 155.1 | 166.9 | 7.9 | 13.7 | 8.9 | 34.4 | 27.0 | 642 | 531 | 200 | 63.7 |
| insert! | 165 x 152 x 23 | 153.2 | 165.7 | 6.7 | 11.8 | 8.9 | 29.4 | 23.1 | 536 | 448 | 174 | 54.1 |
| insert! | 165 x 152 x 20 | 151.6 | 165 | 6.0 | 10.2 | 8.9 | 25.7 | 20.1 | 468 | 382 | 155 | 46.3 |
| insert! | 127 x 152 x 24 | 155.4 | 125.3 | 9.0 | 14.0 | 8.9 | 30.6 | 24.0 | 662 | 231 | 168 | 36.8 |
| insert! | 127 x 152 x 21 | 153.5 | 124.3 | 8.0 | 12.1 | 8.9 | 26.7 | 21.0 | 573 | 194 | 148 | 31.3 |
| insert! | 127 x 152 x 19 | 152.1 | 123.4 | 7.1 | 10.7 | 8.9 | 23.6 | 18.5 | 501 | 168 | 132 | 27.2 |
| insert! | 102 x 152 x 17 | 156.3 | 102.4 | 6.6 | 10.8 | 7.6 | 20.9 | 16.4 | 487 | 97.1 | 118 | 19.0 |
| insert! | 102 x 152 x 14 | 154.3 | 101.8 | 6.0 | 8.8 | 7.6 | 17.9 | 14.1 | 420 | 77.7 | 100 | 15.3 |
| insert! | 102 x 152 x 13 | 152.5 | 101.6 | 5.8 | 7.0 | 7.6 | 15.8 | 12.4 | 377 | 61.5 | 85 | 12.1 |
| insert! | 146 x 127 x 22 | 129.7 | 147.3 | 7.2 | 12.7 | 7.6 | 27.4 | 21.5 | 343 | 339 | 130 | 46.1 |
| insert! | 146 x 127 x 19 | 127.9 | 146.4 | 6.3 | 10.9 | 7.6 | 23.6 | 18.5 | 292 | 285 | 115 | 39.1 |
| insert! | 146 x 127 x 16 | 125.6 | 146.1 | 6.0 | 8.6 | 7.6 | 19.8 | 15.6 | 259 | 224 | 97.4 | 30.6 |
| insert! | 102 x 127 x 14 | 130.1 | 102.2 | 6.3 | 10.0 | 7.6 | 18.0 | 14.2 | 277 | 89.3 | 85.5 | 17.5 |
| insert! | 102 x 127 x 13 | 128.5 | 101.9 | 6.0 | 8.4 | 7.6 | 16.0 | 12.6 | 250 | 74.3 | 75.3 | 14.6 |
| insert! | 102 x 127 x 11 | 126.9 | 101.6 | 5.7 | 6.8 | 7.6 | 14.0 | 11.0 | 223 | 59.7 | 64.5 | 11.7 |
| insert! | 133 x 102 x 15 | 103.3 | 133.9 | 6.4 | 9.6 | 7.6 | 19.1 | 15.0 | 154 | 192 | 73.1 | 28.7 |
| insert! | 133 x 102 x 13 | 101.5 | 133.2 | 5.7 | 7.8 | 7.6 | 16.1 | 12.5 | 131 | 154 | 62.4 | 23.1 |
| custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
